That firmware update doesn’t apply to Unitiserve Clare, unless there is a specific legacy server firmware update that hasn’t hit the beta test group yet.
I don’t think @Richard has said what streamer he is using but that could be covered by the forthcoming legacy update of course…
Ah well 1st gen muso is a different firmware yet again, so I should just wait to see what emerges in the coming weeks (as a beta tester I’m not allowed to say…)
Best
Based on that Naim app vs Tidal app have no knowledge of each other running on the iPhone, I would point the finger at the Wifi router having very limited capabilities. Free routers from Internet Providers have a history of extremely limited capabilities just enough to do some internet surfing.
Can you provide details of the router being used? I think the source of the problem is there.
See section 7 about diagnosing multicast issues. Based on what you describe this all points to a multicast issue on the network, so ssdp discovery messages get lost inside the router. Often its triggered where Apple update their OS, which in turn exposes niche networking issues in the router.
Unfortunately it is one of the more complex sides of networking and often its easier to just replace the wifi router than try and work out what is going on.
Fritzbox routers are relatively uncommon in the UK, yet they seem to crop up here fairly regularly in posts reporting networking issues. That’s just a casual observation, but maybe they’re not the best choice.
Sure, if you can live with it then maybe best to just accept its limitations. Also there’s a lot to be said for keeping an ISP supplied router as updates and support from them becomes smoother. I tend to keep them for that reason, but disable the WiFi and use third party products for LAN use over which I then have more control.
They are frequent in Germany and well regarded, I have used several versions over decades and never a problem. They are also more capable than most ISP- supplied ones over here, so more scope for messing it up I guess
Yes, I’m aware that they are common in Germany. I’m just mildly suspicious of them given the regularity with which they crop up here in network problem posts, but of course there will more than likely be hundreds of them out there working well for every one that causes issues.
I’m sure they have bugs, too, as the one above. I just never encountered one in my use cases - just one additional datapoint. Just saying that they don’t have the reputation of being cheap trash
Just to report that, following the app update to 5.22.2 and a Mu-so reset, I have deleted and reinstalled the Tidal app.
The problem detailed above - that my server (Unitiserve) was not visible unless I closed the Tidal app - has disappeared. Perhaps it wasn’t the router after all?
