I use the Naim App to control Tidal. The problem I have is the Naim App does give the amount of flexibility Tidal’s does.
For example organising albums into alpha as well as not accessing the the full amount of content available via Tidal’s.
Support for Tidal Connect is due to be added to Naim streamers soon, which will allow them to be controlled from within the Tidal app as is currently possible with Spotify.
