Some of us use the Core with no disk at all!
You setup a NAS as the music store, very easy to do.
Yep. Im not sure what the naim core brings over a NAS and poweramp to rip.
Been using Core since they came out upgraded the HDD to a Samsung SSD totally spent inspiration and so easy to use.
On the very odd occasion that it will not rip disc I use iTunes/Music then burn it onto a CD then rip the CD via the Core.
Very easy to install the internal SSD I have a 2TB hard drive connected to the USB at the rear set to automatically update any new rips.
SWMBO wanted one
The other 1000’s of CD I ripped on PC using DBPoweramp, AccuRip checked, tagged with MusicBrainz
What does ripping have to do with the trade in? We are getting very far afield for no good reason in my opinion.
It is on topic, as the Uniti Core is part of the trade in options, which is ripping thingemajig.
I think that is stretching things.
This was the literal question, so truly, it was on topic.
Indeed, and when I enquired and got a quote from Naim via my dealer several months ago, Naim will modify your original CDX2 to provide SPDIF output, as you other wise got in the later CDX2-2 variant however the analogue output then becomes permanently disabled. I have no idea what that designation then becomes… perhaps CDX2m ?
