My ageing amp (82, Hi-cap x 2, 135’s) has developed a strange fault. Sound coming from both speakers but when I turn the balance pot to the right silence. There is a reassuring thump from 135’s when powered up and down, any ideas would be appreciated, my suspicion is an elderly Snaic.
Mike-B, there is the beauty of the forum, I would never have considered the balance pot in my 82, is there any check I can do to confirm or decide the fault lies elsewhere, Guinless raised a valid issue of when the 135’s were last serviced, a long time ago, just wouldn’t have the funds to service all the components, the system was sounding damn good as well.
I assume you mean that when you turn the balance pot fully to the right you get silence, so the right channel is not working? Is it on all sources on all inputs of the pre-amp?
Power down and then try swapping the SNAICs around. If the issue moves to the left, you have found the culprit - faulty SNAIC. If no change, the try swapping the Hicaps. If no change, then try swapping the NAPs. If no change, try swapping the speaker cables. Always power down first before making or breaking connections.
As I said in my first post, if moving the balance pot position creates the silence
… & IF that is the only action that causes the silence, then my money is still on the balance pot.
My suspicion is that you are using 4 to XLR (Cannon) cables between the Hicap & amps with white bands & you have them plugged them into the same input socket on each 135. Your left channel 135 should be connected via the ch.1 socket, the right the ch.2 socket.
No, I have been busy with other commitments and I am hoping to pull out 82 and 2 hicap’s and 135’s tonight, will switch around snaics to see if moving the balance pot to the left will revers the affect. I suppose I should get the whole amp serviced but that would be pricey. If I get away with Snaic cable happy days
