Fixed by logging out and back in via the Naim app.
Yep damn it forgot to do that! Yep logging out and back in sorted it - DOH!!
I last updated from my Mac Mini, but as it no longer reaches the streamer, opted for the Windows update from my laptop. The NDS took noticeably longer to update than the 172XS as it was only on 4.6 and needed 3 updates, whereas the 172XS was already on 4.7 and just did 2. Happy to report no issues.
@YetiZone have right clicked while hovering over Naim update image? If you do this, then manually select āopenā you will get the option to override the security notification.
Edit: see you got it fixed, note self-read whole thread!
The NDS always takes longer than the 172 because there is a lot more firmware to update. Itās not about the versions.
Best
@Naim.Marketing will maybe able to pass this good news back to Naim support so they know if someone else asks the question!
Best
Thanks Suedkiez,
Believe it or not, Iām a beta tester so Iāve done it many times although I suspect this may be my last unless I upgrade to a new streamer. I did brick my old NDX twice many years ago. It had the old Rs232 socket which was a complete nightmare.
Updated successfully
I see. The download link is in the instructions, so I wasnāt sure if youād read them
Clear instructions thanks.
NDS updated without any issues. Took about 20 minutes.
Iām using a macbook pro connected by USB. Iām at the update part and itās been sitting for 10 minutes with 0 lines sent. I suspect itās b/c I didnāt connect the macbook to my switch by ethernet and instead am on wifi. Iāve now connected the macbook by ethernet to the same switch the 272 is plugged into. Will this correct itself or should I abort?
I rather doubt it will correct itself. Did you read the instructions about using a Mac? Presumably so since you got to the lines sent stage.
Iād be inclined to start again personally. You canāt brick the 272 because it will always start an update, but if you canāt get your update to work you may need to ask for more help, for example from a dealer.
I aborted and restarted the updater. Had some issues with ARM/network address but has moved on and is uploading the firmware. Itās about 20% complete now so hopefully it will work out.
All updated okay. Is it really necessary to restore factory settings after an update?
Not essential- keep it in mind if you have any issues, though
Ok, no issues so far. I donāt recall what I lose when I do a factory reset. The display time is the only thing I can think of at the moment and thatās easy enough to put back.
Went ahead and reset to factory default.
Brave man!
Updated to 4.8, no issue so far.
Yes, that would be a bargain. Iād happily drive to Salisbury and pay the Ā£150 for a new legacy green screen update if I could. Here in Sydney the quote is @ $800 for each screen update. (No word on how much for a memory update, or if there was, I forget.)
I realise it wonāt help you in Australia, but in UK at least there is a green screen replacement service available from Naim and it was about Ā£150 plus the courier charge to get it to them when I last used it about 3 months ago. My dealer didnāt know about this by the way and rang Naim to check.
Best
