Lovely Stewart. A serviced 52 is a bit special, isn’t it?
Enjoy!
Best regards, BF
Enjoy!
Best regards, BF
Rushing through some fave tracks and albums. So happy it’s a three day weekend.
Congratulations! It’s something, isn’t it?
What speakers are you using?
Very nice indeed. I have a mixture of chrome bumper and olive which I think works quite well.
By the way, where did you get the glass shelves from? I do have a glass shelf under my Atom but it’s just not quite the right size and a little too thin.
Local glass merchant ![]()
Same glass type / specification as Fraim - maybe use Forum search tools - any local glass merchant could provide custom pieces from 10mm Pilkington safety glass, (with bevelled edge detail), etc.
Thank you. Actually there’s a glass merchant not far from me, I must call in.
And if necessary after a recap session, the combo 52/135 is a storm-bringer: power and charm!
I know this very well! Mine 135 - bought from @khan84 (not directly
) had been recapped in 2018 or 2019 (I think) - bought 135 in 2020 ![]()
Power and charm!
It’s that midrange. So addictive
Yesssss! A magic combination with a NDS /555ps!
Hmmm. Not Olive…….
I would say “honorary olive” especially in non-DR form ![]()
Have you tried getting an olive streamer ![]()
I’ve been toying about the idea to put my Linn streamer to olive case if I found one cheap. ![]()
I do have Superline and Hicap DR as well, so I might be better to leave it like it is.
I’m about to receive olive Supercap for my NAC82 on Friday or early next week and another of freshly bought NAP135 is at Poland for repair. Really happy for the switch to olive series.
Both Supercap and 135’s might need a service. I will probably send those early next year if I don’t get any other issues with them.
Some years ago, there was a chap on one of the forums who 3d printed an “olive” case (sleeve & sled) and mounted a Raspberry Pi streamer in it.
You don’t happen to have any more info on that? I’d really like a way to hide my streamer in something that looks like an olive case. 3D printing is probably the best approach to get the cutouts etc. to match, be able to make it the right depth etc.
Sadly no, I can’t even remember his forum name. But IIRC the case was about the size of an “olive” Headline, which would be about the right size for a Raspberry Pi mobo plus DAC HAT.
Can you not keep the 72/HC/140 whilst you try the 82/HCs/250?
I would stick with 72/hc/140. Easy decision.
