This seems an interesting addition. Is there a way to sync the ones set as favorites on our device Into this new feature in the app?
Apologies, I should have made that more clear. A password reset
@Stevesky
Steve, so I have to create a new account?
Not supposed to use the usual username and pw to log in?
Hi @davidf
This is a different account to the forum one, so yes, create one via the app. There is a link to the terms and condition on that account setup page as well.
Best
Steve
As an aside, in setting up the new account and registering my 6 Naim items, Iāve found 2 (Muso Qb and 555PS) where the serial number is not recognised and will not allow registration. Seems a bit odd.
Indeed it doesā¦. How do you turn it off? ![]()
ATB, J
I really donāt see the point of it. Specific apps for the stations I want are/will always be better. I donāt suggest for a moment that Naim should try and match them. Mineās turned off.
Better that Naim deploy their resources elsewhere imo.
@Stevesky I get the message that my email already exists and I canāt proceed to create an account.
presumably thatās your Naim account that you previously registered - can you reset your password for that account
I canāt listen to BBC3 in HD in the Netherlands. The bbc website is lower quality (bbc sounds is not available outside the uk anymore). So I am happy with this.
Thanks for the suggestion. I did a reset but it didnāt help.
Fair comment! Glad itās good for you.
I also got message to reset PW based on my email. No email was ever sent to me to allow me to reset the PW. This was when I tried to sign in as if I already had an account
I sent an email to Naim support but no response.
I will try creating new account later today and see how that works.
I am not sure I see the point of this. I already have the app for Radio Paradise on my phone and can listen in the car using bluetooth.
Very nice to see Naim developing things, but this one is not for me. Can I somewhere disable this option and have it removed from the startup screen?
Edit: found it!
Yes. From the devices screen. Go into settings, radio player and switch it off.
It works now.
For anyone who only listens to BBC or Radio Paradise stations, using their own apps is likely the best solution. If you use a wider variety of iRadio stations, I think having them all accessible through one app is a good solution. I used to use TuneIn for this, but ditched it some time ago. I like the simplicity, and the emphasis on access to the best available stream quality, that the Naim app offers.
Obviously if this isnāt of interest, you just turn it off and carry on as before.
