Just speaking from naim allae, the cable is quite stiff and long, it was pushing the cable against the joint so it can cause some premature stress on it. Enough force it will start to tear the connection. The cable is not wrapped around the terminal, it is on the terminal.
Good luck with this experiment, bosh.
If it goes well, you will have done a Service to the community.
Hopefully you will not have to do any irreparable damage to the speakers.
Do you know what all the differences between the new and old versions of the tweeter are?
Please upload photos of the process and of your system if you get a chance.
Am sure this mod. (from original to latest Scanspeak) has already been done…
By someone on here…
Try -
or -
IIRC, the SL2 tweeter torque is 0.8Nm and the allen key bit is 3/32.
Best confirm with Naim whether any hylomar is needed between the tweeter and the mounting ring.
I’ve replaced the ScanSpeak’s on my DBL’s along with two refurbished bass units. And a mate of mine blew his mids, which we’ve now replaced with the ScanSpeak alternatives. In both cases the speakers sound fine. My only tips are take photos, pay attention to how Naim tend to dress/coil the internal cables and take your time. On DBL’s Hylomar is required on the tweeters and mids but the bass units are dry mounted and sealed around the circumference with a bead of silicone.
Spent ages last night prepping an update on how fitting of the 852100 SL2 tweeters went in MS word but lost it over night (not in the recovery box!) so here goes again…
Once I’d got first one done which required a journey into Audio Images (big thanks to Andy) for some wire, the 2nd one took around an hour from start to finish
To re-iterate, you do need to replace the wire and if you spin the tweeters 1/4 turn so the solder lugs are at 6 and 12 o’clock you only need to cut out a 10 x 5 mm notch from the tweeter mount ring - I used a jewellers saw (and went through around 5-6 blades in the process) and smoothed the notches off with a 5mm diameter round because I’m like that. The whole job is invisible once re-built so neatness is not essential
Initial listening impressions were positive bearing with the new version sounding at least as good as the old (851100) version. Bear in mind though that (i) the system (NDS555/552/active 500) was cold and will IME take 1-2 weeks to fully warm up again, (ii) the tweeters and new cable needs burning in and (iii) I had also rebuilt the Fraims and done a thorough system rebuild last week following room re-decoration
So all-in-all a very worthwhile process as I now have a relatively future proof solution for some years to come which is comfort (not sure about the bass/mids though)
Great job and good to get confirmation that the hook-up wire will need to be replaced.
Wow, thats a nice job done on the SL2s. May even be a performance improvement coming up as the whole system beds in. So good that naims wonderful speakers are still servicing our love of music. Is there any spec on the new bits of wire needed so that consistancy is maintained, guage? copper quality?
Thanks for posting this!
Mario.
Thanks Mario
I am anticipating it will be an improvement from early findings. The wire Naim used originally was multi-core 4mm2 copper (I think it was stamped 12awg)
As my only “Audiophile” option for a quick collection was my local Naim dealer I was anticipating coming away with NACA5 but they suggested the more malleable Chord Epic X which I used
Very interesting. And there was no blue hylomar between the tweeter and the frame?
There was some darkish green/black gunge on both the old tweeter and the O mount ring, but bear in mind the tweeters have been replaced at least twice and and I’ve not used any Hylomar or the like and did previous replacements
I did contact Naim late last Friday regarding the required cable spec and asked about Hylomar, but the Tech guy I spoke to said speakers were before his time and to Email the enquiry in and Class A said they dont do speaker repairs
Perhaps Richard could get the definitive answer on both of these
I’m sure @NeilS could ask Clive or Mike whether they recall whether Hylomar was used between the Tweeter and the arm ring on the SL2.
I don’t recall Hylomar when I replaced my SL2 tweeters a few month’s ago.
Massive thanks to Clive for his out of hours assistance:
“Yes there should be Hylomar. About a 2mm bead round the metal ring in line with the fixings. Torque I think was 0.8nM on the 4ba bolts.”
As for the wires, I can’t find a definitive spec, but they are 4mm CSA, 56/0.3 strand copper, manufactured by BICC to the best of my knowledge. Look closely at the wires - I think they are printed with some data?
Neil.
That’s great, thanks Neil (and thank you Clive!).
IIRC the hook up wire used was RS 56 strand, which is still available from RS Components.
I believe that RS 56 Strand was the standard Naim recommendation, for speaker cable, , pre the indroduction of Naim NAC A4.
