Naim Snaic 5 Question
I have two Snaic 5s. One says naim snaic on it with a green band , and the other just says snaic and has a white band with the olive logo ( 2 knobs pointing downward ) on it.
I know the one that says naim snaic is newer, but which one is better?
Thanks.
If they are both Black, the same.
If one is Grey, then Black one is ‘better’…
Yes they are both black. Ive never seen a grey Snaic that says naim on it…OK they are sonically identical then. Thanks,
