Naim snaic question
Hi,
I have an opportunity to buy a 2nd hand Naim snaic. The snaic is advertised as being able to connect power supplies including a flat cap/flat cap 2 to devices such as a CD5 and Stageline/superline. Can anyone tell me if it can also be used to connect a Flatcap XS to an NAT05 XS tuner? The seller does not know.
Aidan
Ask him to confirm how many pins are on each end. It’s either 4 or 5.
If it’s a Snaic 5, ie with 5 pins at each end in a 270° configuration, then it will be fine. If you post a picture of it we can say for sure.
Thanks both. I will check with the seller.
Aidan
It should look like this, with the same 5 pin plug on both ends.
The FAQ here might help:
Belated thanks for all your advice. I bought the cable sale or return and it’s fine.
Aidan
