Thanks, yes I’ve looked at cable dressing and nothing obviously wrong. I’m convinced that whatever is causing it is internal to the N50 rather than coming from outside it. It’s not actually bothering me as far as listening goes as it’s only audible very close to the LH speaker. I only noticed it by pure chance actually. My concern is two fold really. Does it mean that my N50 is faulty (in which case it needs fixing) and could it be symptomatic of something which could actually be impacting on performance. Although I can’t hear anything wrong, I wouldn’t necessarily know if it was impacting negatively on performance as I’ve never heard another N50 to compare it to.
It’s difficult, if not impossible really to say from behind the computer. In such cases perhaps best to speak to your dealer. That’s part of what they’re there for you when you buy from them - to check out any install issues, answer any questions, take care of any niggles, and generally provide some peace of mind to the purchase of any piece of kit you buy from them.
Thanks Richard. I’ll speak to my dealer and see what they say. In a way I’m loathe to actually have it tinkered with while it’s sounding so good but obviously if it’s poorly then it needs fixing. So what to do? Just forget it or get it checked. I appreciate that in such instances it’s difficult/impossible for anyone to be able to say for certain whether something is within normal limits without actually hearing it for themselves. In which case my dealer will probably send it back to Naim for checking. I don’t want to do that and have it returned no different and then it will all have been for nothing. So it’s a bit of a quandary.
Hi Pete – I’m assuming you have a warranty on the N50 ? If so, I would keep an eye (ear) on it but given the noise is at such a low level and only noticeable right next to the speaker, then I really wouldn’t worry at this point.
If it gets worse, then it’s worth getting it checked, but for now I would just forget about it and go back to enjoying the music.
Hi Pete
Oh dear not nice to read this.
I imagine having a dig through the thread you’ve tried the speakers in each others channel and it was the same speaker making the hiss.
This doesn’t seem like the amp is at fault but one or other speaker is slightly more sensitive than the other by a tiny margin.
If all the troubleshooting follows the speaker it would point to them.
Switch it all off and unplug everything one at a time and reconnect cleaning all the sockets and see if that helps.
Hope is ok ![]()
You’re overthinking it. Stop worrying and just listen to the music. You think it sounds good and you know what good sounds like so why fret over it? Take a chill pill
Thanks @Skeptikal and @james_n . I haven’t tried swapping the speakers over yet but I will. Basically apart from this I’ve tried all that I can really I think. I kind of doubt that it’s anything to do with the speakers, but you never know, I’m minded to just leave it alone, but my OCD sort of makes me feel that I should do something!
Yes, and if it is faulty then I obviously need to address it within the warranty period.
I understand the OCD the easiest thing to try is swap the speakers over and see if the hiss moves. ![]()
If you still own your old amp, try that and see if the issue remains.
As @Skeptikal says Pete, but also not just Naim but other equipment I’ve found all sorts of gremlins that go away once turned off and unplugged from the mains (cable out at equipment end) and leaving overnight / few hours before reconnecting.
I’m not saying its something I have done regularly but on a few instances over the decades it has proved beneficial or at least to help if there is something that needs more inspection.
@70sPete My worst one was a grounding type buzz that I could track down until everything was unplugged and then built just the system up one by one until the buzz returned. Turned out to be my TV, which the day before was fine and then this day decided to pollute the mains. It was an old Panasonic flat screen which was obviously showing its age. The classic nothing has changed, other than time, and that was enough for it to start to affect things.
Very faint hiss here on both tweeters with ear to the speaker, quieter than on the Muso 2. Increases with slight hum at high volume on the phono input. All as expected.
Interesting. Are you a diagnosed OCD sufferer?
Thanks Skeptical. Will give this a go this afternoon.
No, I was only joking really, but when something like this happens I do feel a, (perhaps unreasonable?) urge to get to the bottom of it. Many N50 owners, including you, don’t have this noise so I’m bound to think there’s something wrong. Your Dali Menuets are about the same sensitivity as my JBLs so why no noise for you and noise for me? Assuming no external cause, which I think I’ve ruled out. Could just be normal sample variation, in which case just my hard cheese, or could be a fault. I want (need!) to know which in order to satisfy me!That’s just me and others may not be worried.
I’m glad you’re joking because true OCD is no laughing matter. I do sympathise though as these things can play on your mind if you are an overthinker which is why I sent my original unit back. My guess is that what you are hearing is completely normal and not detrimental at all. If it’s not broken don’t fix it and you are happy with the sound so carry on as you were.
Really? Is it a debilitating condition? I’m a mental health first aider and was shocked at how OCD can affect some people.
Very sorry to hear that Skeptical. It’s not nice at all. For all I know I have it too. Just no formal diagnosis since I’ve never approached anyone about it. I do think though that although these things can debilitating if severe they can also be beneficial as they can cause you to focus on things in ways that others don’t and this can get results. At mental cost though which is definitely unpleasant. Hope you are getting along OK anyway and at least you are enjoying your music and hi-fi.
Trust me Pete there is no benefit from severe OCD. What you are describing is attention to detail, overthinking and probably anxiety. I think the term is used completely out of context in general these days.
