Nait 50 Very Slight Buzz
Understood. I’m no expert and apologies if it seemed like I was trivialising it - I didn’t mean to at all.
My apologies to @Skeptikal too. Sorry if it seemed like I was trivialising OCD - I didn’t mean to. I know it’s thoroughly unpleasant and my comments about it being in some ways beneficial were misplaced. Do please forgive me.
Hi Pete
No need to apologise whatsoever.
The type I have isn’t about cleaning etc it’s very disturbing at times but trying to keep busy and interested in things helps.
Probably why I’ve got an intense sense of humour sometimes.
In a world of chaos distraction is your friend.
There I’ve said it out loud. :partying_face:
Not all Pete, if you don’t know you don’t know. I had to complete a week long course to become an MHFA and it was only then that I realised just how awful OCD can be for some people. FWIW I once had extensive CBT treatment for Clinical Perfectionism and I suffer with it to this day. It’s something that I can use to my advantage sometimes although I do suffer with terrible imposter syndrome and social anxiety because of it. The mind is a complex thing
Thanks for explaining Skeptical. It sounds very unpleasant and you have my every good wish for it to improve. I do recognise some of the things you and @AndyKH have said in myself. This buzzing is making me thoroughly miserable and I’m finding it hard to think of other things that need doing. I’m pretty certain that it shouldn’t really be affecting me this much.
Just swap the speakers over.
See if the hiss moves or not. :thinking:
Sounds awful Andy and yes the mind can certainly do all kinds of very unpleasnt things. I’ve always been a perfectionist though I’ve no idea if it would be regarded as clinical or sub clinical in its degree. It’s definitely caused me problems though. Apart from anything else spending huge amounts of money in my pursuit of the perfect sound which I know logically can never be achieved. But that didn’t stop me. When I think that I spent well over £7K on mains blocks and cables in my previous system in pursuit of perfection it now seems entirely unreasonable to me. Yet at the time it seemed all good. I bitterly regret it now.
I hope also that you are getting on OK and you also have my every good wish.
Hi Pete. I’ve just done another hiss test and I’m getting speaker hiss from both channels, one more than other, when volume is at maximum. I get nothing at my normal listening levels. Just for clarity it’s a hiss not a buzz. Hope this helps.
Thanks Andy. That seems different to what I’m experiencing. Hardly any hiss at any volume setting and the buzz is independant of volume setting. I’ve always had far more hiss from previous Naim amps and the Nait 50 is much better in this regard I think.
Shut everything off. Then disconnect everything from the NN50 except the speakers. Turn the NN50 on noise gone?
I’ll ty this this afternoon too. I only have a CD5si connected though and when I switch to the other (unused) line input it makes no difference.
I’d try switching the CD player off at the back, and unplugging its din lead. It could be the two transformers interacting somehow. As many have said, hiss is normal but buzz isn’t, and it sounds like it could be a mains issue. Are either of the speaker leads near a mains cable; if so they should cross at 90° and not run parallel.
If that doesn’t stop the buzz I’d suggest you speak to your dealer. It’s clearly worried you enough to start a thread about it, so you want to get to the root of the issue. People can say don’t worry, but that won’t stop you worrying. Hiss is normal, buzz isn’t.
Hi Pete. I know my financial limits and also how in this game you just have to stop when you’re happy.
I agree. Worst place in the world for me is in bed with a racing mind. It’s an awful place at times but I won’t let it beat me.
I’ll try that. Both speaker leads do cross mains cables (Powerlines) at 90 degrees. The lead to the LH speaker (where the buzz is) I notice runs parallel to a Powerline for maybe around 30cm. Stupidly I hadn’t noticed that so I’ll experiment here.
Tried moving the Powerline and disconnecting the CD DIN lead and no difference at all. I’m now convinced that whatever it is it’s internal to the N50. Thanks for the suggestion anyway.
Did you also try turning the CDP off at the back?
Hi Skeptical Just tried swapping over the speakers and the buzz doesn’t move. So the N50 I guess.
Yes, turned off the amp first, then the CDP, then disconnected the DIN lead, then just turned the amp back on.
Hi Pete is it a hiss or a buzz? I’m getting confused now​:slightly_smiling_face:
