Pete, do you have another DIN interconnect to test with; could either the DIN connector on the N50 or the lead be wired incorrectly. I recall @Simon-in-Suffolk encountered an anomaly that was audible with his N50 which required a trip back to Naim to resolve, I think the culprit was the DIN.
it was some swarf in the DIN socket mechanism and a slightly out of tolerance signal input relay. The result was that the affected channel didn’t sound as incredible as the good channel.
Slight drift same thread
How did someone manage to like my post with a thumbs up.
Every days a school day.
@anon22505844
Thank you for that must be new. ![]()
Top of the class for you. ![]()
Someone has pressed the “make it feel like WhatsApp” button.
we need “contextual-emojis” to be fair; there’s some ridiculous hilarity that needs the correct emoji applied on this forum !
I disagree. Whilst many of us have experienced one or more of those, none if them are a given. My HC DR 2 buzzed. My other HC did not. Both in the same system. One for headphones. Dealer tried the “Oh but they aleays buzz slightly.” line but backed off on seeing a photographic reminder of my system. Replaced the HC DR 2. The new one made zero noise.
My 200 objected to Sunday mornings.
Just got back from a day out in Leamington Spa with my wife which provided a much appreciated diversion from the buzzing problem. Thanks to all for the helpful replies. I have now tried reconnecting the Power Lines as suggested by @Richard.Dane They were already in as far as they seem to want to go though. I applied considerable force and wiggled about but they won’t go any further.
Thanks @Skeptikal . I’ve tried it, but still the same unfortunately. ![]()
It’s a fair comment. I am a bit (who am I kidding? A lot!) like that yes. As much as I am trying to forget it all and just enjoy the music, which is what I really want, I find it very hard to let go of the urge to improve things. I don’t want to, but feel compelled to! Don’t know what a trick cyclist would make of it. I guess I’m all screwed up in the head! I need to work on this for sure. Even today whilst walking around in Leamington I was mulling over the possibility of getting a used CDX2. Very bad idea. I must fight this!
Seems I’m not alone then. It obviously happens. Whether it’s actually a fault or considered within normal limits of sample variation I don’t know.
Not sure where all this leaves me. Clearly a swap for a new Nait 50 isn’t an option anyway.
I have a (perhaps misplaced) feeling that if I get it back to Naim it will come back to me no different. I think the most sensible thing at least for now is to ‘ride the beast’ as it were and see what, if anything, develops. It’s not actually causing a problem as such, at least not that I’m aware of, but I do hate loose ends - and it is a loose end.
Others have had them swapped out Pete.
Yours shouldn’t be any different.
You’ve now done all the troubleshooting and it’s obviously now coming from the N50.
It’s proven not to be right so a replacement or at least a check over or repair is due.
Don’t let them grind you down if it’s not right it’s not right.
I wouldn’t accept a fault that others don’t for sure.
Why isn’t a swap out possible? Can your dealer come to you and swap out the Nait 50 and make sure everything is resolved. If you bought the rest of the kit from them, I would have thought that would be mandatory.
I am not saying that every box hums. I am sure you realised my point. Naim systems have noise whether it be slight hiss from speakers or transformer hum.
You have demonstrated that boxes in your Naim systems have noise! That was my point.
My N50 has always had a sort interference on the phono input, a bit like a rustling type sound thats never gone away. As I use a separate phono stage into the aux input It doesn’t bother me as its silent on the stream and aux inputs.
Thanks Skeptical. Yes you’re right. Obviously it isn’t as it should be when others have it silent. Looks like I’m just going to have to have it looked at or I’ll never be happy with it. ![]()
I assume there are no new ones left for it to be swapped with by Naim or my dealer. Mine has a very slight nick out of the edge of the front CB casework, despite being a brand new sealed box. The best my dealer could offer, aside from a refund, was either a discount or to swap for their demo sample. I took the discount. Normally there’s just no way I would accept something like this but I was very lucky to get a new one and getting another from elsewhere didn’t seem like an option.
Thanks for explaining the situation further. See if he can get anothwr new one for you immaculate no marks from Naim, under the circumstances. I am routing for you my friend!
Thanks Dan. If Naim still have any then I would definitely want a new one both in view of the buzzing and the cosmetic damage. I had just assumed they are all gone now and that this just wasn’t an option. Maybe I’m wrong though? I’ll give them a ring tomorrow.
Keep pushing @70sPete and get them to check it thoroughly for the same issue before sending it to you.
As recompense you want a brand new unit with no issues. I think that’s a reasonable ask.
Why would a new unit be provided?
Surely it’s a warranty issue and deeemed an inspection/repair by Naim?
One of my 2 NN50 has a very slight scratch on the top casing, must’ve been missed by QAQC but I never thought to query it………
Perhaps I ought to……..
I opened maybe 2 years ago the same thread and was happy that a lot of members tried to help me, as here. “ don’t bother, try to connect a cable from the chassis to the earth, try the Audioquest power conditioner, maybe your left speaker has a problem, change the amp ,etc…..
I decided to follow my intuition. Bought an Ifi dc blocker from Amazon, 100 euros, put it between the NC 250 and the power cord: Eureka! Problem solved.
