Yes I’ve defeated the auto standby mode, so it’s alawys on unless manually switched off. I just leave it fully powered all the time for maximum sound quality (IMO). Interesting about the AC inlet - could be relevant here and kind of ties in with what was said about the instance of a Nait XS2 with hum on one channel.
I wouldn’t part with the Nait 50 though. The best Naim amp I’ve owned for sheer fun and musical enjoyment IMHO bar maybe the 42/HiCap/110, but that was such a long time ago now that I can’t be sure. I’ve just come to accept over my many years of Naim ownership that Naim products are often a little quirky. The price one pays I guess for what is, for me anyway, their exceptional musical ability.
Pete, it might be worth trying the standard power lead as already suggested. Why? Because it could be that the Powerline is not fully pushed onto the pins of the IEC and so arcing slightly which may be the cause the of the slight buzz you’re getting. Try it, or else remove the Powerline and re-fit, making sure that it’s pushed home all the way past the initial resistance.
Hi Richard, thanks for the suggestion and I will give it a try. I’m pretty sure that it’s fully home though because on fitting I had to push very hard and I couldn’t get it in any further. It looks OK, with the same amount projecting from the IEC socket as with the CD5si, ie, around 5mm before the actual plug barrel. Actually on reflection that seems rather more than when I had the Powerlines plugged into my previous Moon gear, but this may just be IEC socket variation. I’ll definitely double check this today though.
Thanks Richard. There’s only the CD5si and Nait 50 in my system anyway, nothing else connected, both with Powerlines, so I’ll double check both. The TV/Blu ray player/router are unavoidably nearby on the same circuit unfortunately and I did suspect them but tried switching them all off but no difference. They aren’t connected to the hi-fi.
TBH I don’t know for sure. It’s extremely faint and I only noticed it by pure chance when I was carefully dusting the speakers yesterday. Had I not done that I would still be blissfully unaware of it! We’re talking really, really faint - but there!
might also be worth connecting all the equipment in your room to a multi-out power block momentarily to see if that defeats and ground looping that may be occurring from multiple socket use to multiple users.
however, if as faint as you suggest, just play it till it pops ?
Forgive me but I feel your pain and want to help (however limited that may be). As I understand it the only source is CD no turntable connected to phono input.
My NN 50 has a faint hum only on phono selection (not enough to interfere with enjoyment). I have looked at all sorts of options to sort however.
I wonder if hum is due to that sensitive phono stage. If so not a lot you can do bar physical separation from CD5si and any other local power sources.
Given I understand CD5si has floating earth it may be worth earthing NN50 directly in case that is the issue. On recent visit my dealer mentioned they had advised that for a few owners. Usually for TT but the principle should apply. My dealer had offered the wire and plug made up themselves so not something I would choose to do myself.
Again despite re reading thread I may have missed something that invalidates by advice.
The 5Si follows the normal Naim source convention of providing the signal ground to mains earth connection. Where it differs to some of the other products is there is no facility to ‘float’ this connection via a switch.
Thanks @alg777 . May be worth a try yes. I take it that would mean just running a cable from the earth connection on the back of the N50 to a suitable earth point, such as a 13A plug (earth pin only connected)?
I did think this was the case so I guess nothing to be gained from an additional earth connection, which I assume could cause a problem then (ground loop?).
Exactly. You don’t need an additional earth with the CD5Si as your source. As Alg777 points out, this may differ with a different (non Naim) source.
Your posts have made me curious as to my own N50, which is sat unplugged on my desk at the moment, so I will connect that up later today in my main system and see if I notice any buzz.
The problem hiss or buzz with @70sPete system is only in one channel and moved when he swapped the speakers over so point to something down line on the N50 side.
The only other thing to try is with nothing connected except the speakers then that will eliminate anything else.
I thought I read an earlier post that although not as loud was present in right speaker too but take your point. Problem is, as I have found once you find ‘fault’, everything gets amplified (no pun intended)
i bought one last yr that had a noticeable mains hum on one channel with ear against speaker and it was swapped out and the second one had tiny amounts of hum but equal on both channels and only audible with ear against the cone. No worse than any other amp i have owned, especially as its high gain and a lot crammed in a small case.
