Lots written about this on here but my tuppence worth:
I’ve tried both now over the period I’ve had the ND555 and have come down decisively in favour of the HiLine. To my ear it sounds more balanced and less ‘clinical’. It times better too, giving the overall presentation a more natural and propulsive addictiveness.
My preference on the NDX2 was the opposite strangely, and I initially assumed it would be the same with the ND555.
For me the Morgana just nudged past the post on SQ. To me it is part of system tuning (room tuning)……i can fully understand a different outcome in another room or system.
For me having to play with a cable to get it to seated right, if indeed you actually do need to, then it is surely a bad design?
I get about it touching things, but can’t see what difference pushing the end into a socket will make, it either makes contact or it doesn’t? As long as its pushed right in, then can’t work out what you can change
When you look at each end of the DIN to DIN HiLine cable you can see that each of the pins inside the DIN connector will move around when the cable is adjusted.
I’m no expert but can only assume that it may be related to getting the pins inside the HiLine’s connectors to line up correctly inside the DIN connectors of the source and amplifier (obviously in addition to getting the HiLine to hang freely)
My ND555 & 252DR are low to the floor so the HiLine loops round horizontally between the two. It’s propped in the middle by a kitchen sponge so no strain at all on the plugs.
A push firmly in to seat and a gentle pull out until it grips isn’t too much of a carry on.
I know the pins are floating, but they can only go in one way and once in the slot there is no other way, so dont get the statement messing about with seating
You would have just loved some of the early prototypes. They looked so fragile - just pins and rubber bands! The final design for the hi-line was built like a tank by comparison.
It’s a remarkable thing the Hi-line. And it works too, as I discovered having to test them at the factory during a spare half hour or lunch hour. It’s pure Naim - both brilliant and crazy too.
I agree with my Naim dealer…DIN/DIN from ND555 to NAC552…
In order best to worst:
Ansuz D2
Chord Music
Super Lumina
HiLine
I’m a fan of HiLines but I kept breaking them.
All these cables are developed using human ears.
Chord have a Naim NAP 300.
Ansuz build amplifiers, speakers, cables, etc.
What does Morgana use?
