Can anyone confirm if their naim streamer is reaching out to your WAN over TCP even if it is switched off.
I am very security aware and notice my naim ND5XS2 streamer is reaching out to two IPs even after the ND5XS2 has been switched off for 4 hours. I stopped listening to my streamer before football started today, and nearly 4 hours later I still see established states over the TCP protocol.
The middle state I understand. This is mDNS and is completely normal.
The other two states appear to be Google servers, one in the UK and one in Brussels.
My ND5XS2 is completely isolated on its own VLAN with no other network devices allowed on there, fully locked down.
Any network specialist on here finding the same behavior?
Did you even read my post? Youāve repeated what I already said in my OP.
It appears Naim are selling our data to Google. Iām currently packet sniffing and can now see what requests are been made. Luckily Iām already blocking Google from sniffing my privacy so they get nothing back from me - but I canāt stop the ND5 XS2 from constantly trying to reach out.
What makes me angry about all this is the GDPR hoops I have to jump through with my job, but Google analytics can try monitor my every move 24/7.
Yeah there must be a lot of valuable data you are leaking there. I expect a big corporation or a nation state would pay 0.000001p for a yearās worth of such data.
@IainO - you are completely missing the entire point and I am unable to educate you unfortunately.
I appreciate my Android/Google phone reaches out to Google as that is obvious! What I didnāt realise is the need for my Naim gear to reach out to Google - and certainly not when my streamer isnāt even switched on.
You know it has chromecast in it?
All the answers have been provided by Steve already. I guess if you want you can try to block all that data, but then you might prevent or disable some of the functions of the streamer from working.
The data must be valuable to someone, otherwise why collect it in the first place? Iām just looking for clarification as to what the data actually is.
I did think my question was quite legitimate. Eeek.
Looks like Iāve stopped all these handshakes now, so all sorted. Cheers for the help people.
Spot on, and 224.0.0.251 is a group multicast address on your home networkā¦ so goes nowhere near the internet/WAN. It is a multicast discovery address when using the shown port on your home network subnet, almost certainly mDNS/Bonjour.
Further 224.0.0.0/24 addresses canāt be routed, so it logically can not communicate outside of your home network subnet, even if you wanted to. So given that the OP has created a separate subnet for their streamer, they are crippling some capabilities with their other home network subnets unless they have programmed helpers within their internal router.
Its worth knowing in domestic consumer network audio, most applications are designed to work using network methods that work within a single subnet/broadcast domain.
Sureā¦But if youāve set up VLANs then youāll likely also know the need for some inter VLAN routing ā you would need one directional communication for access and control at the minimumā¦.
With UniFi at least, Multicast across networks is a one box tick of the mDNS option in global network settingsā¦(Though knowing UniFi it probably doesnāt work 100% )
I currently have my audio in the main ātrustedā networkā¦but you could argue the case whether it actually belongs in a IoT subnetā¦
And I agree ā thereās a heavy manufacturer presumption that devices will be homed and operated in a typically flat 192.x.x.x network run out of a ISP one box router/modem ā¦.
Yeah I wouldnāt get hung up with VLANs, that is simply trunking multiple subnets together down a trunk with tagging. Those VLANs will represent seperate subnets which will need to be routed, using a router with routing tables.
Helping mDNS with a tick box across the router sounds like a prepfrrammed helper. However you will need other helpers for SSDP (which uses a different multicast group address) as used in UPnP as well. It can all get quite involvedā¦ and really of marginal if any benefit.
Partitioning subnets like this for āsecurityā reasons is very old school, and not really that effective unless a firewall or equivalent.such as SDLAN contracts are used.
BTW the single broadcast domain used for home networks with ipv4 can equally be Class A, B or C. Class C networks (192.168.x.x) can only have a max subnet size of /24 which is 254 host addresses, which for most home networks is sufficient. Increasingly ipv6 is not constrained this way, and for IoT I suggest really is better managed in an ipv6 defined subnet
Well of courseā¦in my case the UXG Proās own. If I was ever to change from that, would probably be pfSense I guess.
Re VLANs, Iām not so sure theyāre that old schoolā¦! Seem to be increasingly practiced even at a domestic level, let alone business and commercialā¦Aside to elements of security, I like the logical separation they offer within a networkā¦
Yes of course. I was just meaning that āfor mostā end users, home networks are set up in typical default styles out of the supplied ISP router, most often a flat Class C.
VLANs are not old school in themselves, i use them much of the time , using them as some elementary network micro segmentation method for āsecurityā reasons via a non firewalled or equivalent router isā¦ and of questionable benefit and unnecessary complexity, it adds no effective network security when using switches ā¦ other than with very large sub networks where you might want to manage and limit broadcast domain overheads.
If you like the idea of object defined networking, you should look at software defined LANs (SDLAN) ā¦ but as far as I am aware such tools and fabric type switches are not readily available for consumer home networksā¦ā¦, also network based security these days is increasingly focussed on user/ service based authentication via AD and/or certificates or similar , rather than relying totally on network segmentation boundary controlsā¦ but I guess home network products and services will take some years to catchup as they usually do.
The best home network security methods you can do these days are to ensure all hygiene products, product patches and operating system patches are upto date and current, and practice good hygiene methods on emails, web sites and software downloaded. https://www.ncsc.gov.uk/section/information-for/individuals-families
You donāt need any fancy home network product setupā¦
Which state is the system in?
Network connected standby? (E.g. via the app, the remote, a short press on the front button, or via standby timer.)
In this state the unit is not off - you can wake it from the app, the remote, or also AirPlay/Chromecast/ā¦ (depending on which inputs are enabled.)
You can also send the system to soft-off, usually via a long press on the power button at the front of the unit. I never checked, but Iād expect the unit to be ādead to the networkāin this state.
