nDAC digital input interface lights
I’m using the nDAC in my system and I’m able to playback through all of the different digital inputs, all are functional. However when the music is playing only the SYNC light illuminates none of the corresponding 1,2,3,4 buttons light light up.
Are the corresponding selected input lights supposed to illuminate during playback?
Assuming that the 1,2,3,4 buttons light up temporarily when selecting an input then it sounds like the lights have been disabled.
Have a look at this:-
Hi ajm - Thanks for the prompt response! Yes a the lights do function temporarily when selected so fortunately it’s not a malfunction. Taking a cue from you I’ll leave them off.
Nice one :+1:
I’ve learned something about the nDAC.
Thanks for sharing…
