Hello all from Down Under!
I’ve initiated a new topic seeking your insights on selecting the right speakers for my NDX2/SN3 setup. I decided to create a separate discussion to avoid hijacking a similar ongoing topic, which I’m also following closely.
To provide context, I have attached the floor plan of my living space, including the current speaker configuration (B&W 684, which I’m going to sell). The room has an open layout, combining the living room, study, and kitchen, with an irregular form. One wall is entirely glass, from floor to ceiling, while the other walls are thin plaster, and the floor is carpeted.
For my listening preferences, I mostly enjoy classic jazz and classic rock.
I’m currently exploring three speaker options and would greatly appreciate your insights:
a) PMC Twenty5 26i - Brand new
b) Audiovector R3 Arreté - Ex-demo
c) Focal Sopra 2 - Brand new
Options a) and b) fall within my budget constraints, while option c) stretches it by around 30% (or should I say ‘only 30%’ given that it is still possible to find reduced-price stock in Australia).
For option b) (Audiovector R3 Arreté), I’m concerned about the brand’s limited representation in Australia, potentially affecting after-sale support and resale value.
For option c) (Focal Sopra 2), my main worries include its dimensions, particularly the footprint of 358 * 540 (W * D), and the sheer physical size of the speakers. Given the size and layout of my room, and the fact that my amp is the integrated SN3, I wonder if the Sopra 2 might be overkill.
I would greatly appreciate any advice or experiences you can share regarding these speakers. Additionally, if you have alternative speaker recommendations obtainable in Australia that could complement my NDX2/SN3 setup, considering my musical preferences, please feel free to suggest them.
Thank you in advance for your time and expertise. Looking forward to your insights.
Best regards,
