It should yes. It buffers the input/output.
what if the buffer board is not installed like my photo above?
What will happen ?
Probably more one for @NeilS⦠Iāve never run without, but I guess itāll work, just donāt try using the tape in/outs with anything.
So of the 3 DINs that can be freely used only the tuner ?
Cannot use tape IN and Tape OUT?
You mentioned you had been offered this 72 by your friend? How did they use it?
More importantly have you bought it? Because you might find a better more complete one elsewhere.
I got an offer, but I havenāt bought it yet.
I hope not to be disappointed if I have purchased and know if there are some boards / modules that are not installed.
When demonstrated, I saw that the CD player connection was to the tuner input, but I wanted to find out if the other functional inputs could also be used
Correct Richard - they are the tape output buffer boards. the only consequence of running without them is no tape outputs. The inputs will still work ok.
In theory, if you donāt use them, it will sound better without them as there is less current drawn from the power supply.
I seem to remember some unofficial advice from somewhere to remove them for that very reason(?)
Neil.
So if the Buffer Board (NA324) is not installed like my photo above, the only thing that doesnāt work is Tape OUT for recording, right?
While the Tape IN is still functioning normally?
So based on my photo above I can conclude that:
- DIN Tape IN = normal input
- DIN Tape OUT = output does not work
- DIN Tuner input = normal
- BNC AUX input = does not work
- BNC MM / MC Phono input = does not work
my difficulty is finding boards: NA326, NA322, and NA324 after this ā¦
Neil, thanks for clarifying.
Does the seller not still have the boards?
Yes, he doesnāt have boards yet (324,322 / 323, and 326/328)
do you have it ?
Contact Darran at Class A as he stocks these boards and sells them serviced for less than eBay.
Tom Tom will also have them.
Yes, I have them in my own NAC32.5 pre-amps, but Iām not sure thatās relevant here.
Without the boards I would only consider if the price was very attractive. A pair of phono boards can easily run to £100 secondhand, even before a service, so you need to do your sums carefully.
@Musicianandteacher
thank you, I will contact him shortly
Yes, therefore I am very grateful to all in this forum who have helped and provided me with very valuable information.
In such conditions, how much respect will the NAC-72 be?
Because board prices for 322, 326, and 324 are not cheap ā¦
Primemerkava, this was also a helpful thread
Iām not up on current secondhand pricing. If it were me, Iād probably want one with the boards already inside though, unless it was going very cheap.
@Richard.Dane
Thatās right, thatās a careful consideration, while waiting if there is a board with a reasonable price for used and normal goods
@all
Is my conclusion above correct with the condition of the board that is installed like my photo above ?
Personally I would pass.
Those 3 din sockets look like they could be worth replacing, though they might clean up ok.
