Interesting - OPTIMISED to be positioned like that, or designed that it doesn’t matter.
These things are important ….At the moment I have them planned to go each on a dedicated Fraim level below the Turntable itself. So effectively “stacked” albeit each in a Fraim level of its own.
My point is, these two components were designed to be minimally compromised from sitting side by side. From internal layout to external casing, they are different to previous designs in many respects.
As with set up and use, we tried to make Solstice less daunting than many other high-end turntables, with endless rules etc.
I could compare the Solstice with Nd555 for two tracks, from two albums that are well recorded both in digital and vinyl. I know, 2 tracks is not enough…
I found the Solstice more laid back vs the Nd555, with less bass and details. But still the involving and organic sound we cherish.
My feeling is that the phono or cart are not on the same league. With a Superline / Supercap and better cart, the Solstice would have the edge I think.
…don’t forget, FR, that conventional wisdom in getting the signal to the phono stage is that the TT is significantly more important than the arm…and that the arm is significantly more important than the cartridge.
Just sayin’.
…but, using the rationale I described, substituting in ‘better’ arms or cartridges might not result in improved sound. Also, bear in mind that the package was (probably) developed together as a whole.
I thought you were saying the contrary. So we agree to disagree. It was developed in the limits of a certain budget, not because precisely that cart and phono are the best for that deck.
