Thanks Chris, much appreciated.
might want to add HiFiOne to that search…
Thanks, that’s good advice. I did eventually manage to find the right site, but there are more than 20 Rick Browns in Carlsbad.
I see that ChordMusic Phono is another option for Solstice. But looking at the description on the Chord website, you can choose either straight or right-angle DIN connector, and slim or reference cable, depending on the geometry of the deck. Which version is compatible with Solstice?
Other than a confirmation from Chord that their Music cable is compatible I don’t know the details. I’ll inquire and ask which DIN they use.
Okay, thanks. The other issue is thickness of the cable. I have a Music interconnect, and it appears to be too thick to fit under the deck.
Did you add that new pair of SL2 tweeters yet?
And can it only be played backwards today? Hint, hint
