I must say I was severely tempted to switch from a high-spec LP12 (via break-up values) in to the Solstice TT as, like others who have posted way above on here, the continual LP12 updates from Linn simply feel ‘wrong’ (drip, drip), and their pricing punchy. There would have been a material costs gap, but OK, it would be a present to myself. But, I had reservations regarding long term support for the Solstice and what the package aspect meant (via adaptability e.g. I have a TKR, which would make no sense to sell). There was also the limitation of the burndy, which could be problematic with the wall shelf plus, of course, what to do with the phono stage, as I already have a SL.
It seems, blessed with what’s now been revealed, a bullet was dodged, as this has all the looks of a deck which cries out to be pimped based on the reputation of the ARO and the provenance of the TT with all its features via Clearaudio. OK, it can be done as @Cohen1263 has kindly detailed, but this isn’t how higher-end TTs are supposed to be – and it’s not as Richard suggested (not his fault) way back in this thread:
Honestly the amount of guff and hand wringing from people on here who don’t even own a solstice, and many probably not even heard one is astounding. If you want to constantly tinker and are suckered into linn’s marketing led constant upgrade model then get an LP12, pay your money each year for upgrades and be happy, you are not the target market for this deck. For me I listened to the solstice vs a klimax LP12 and bought the one I preferred. Never have any intention to modify it, Naim (via my dealer) have assured me that the equinox will be available for the foreseeable future so all is good. If I can’t get an equinox I’ll use a different cart and do whatever is needed to make it work.
I bought a Keel/A for my LP12 a few years ago. Other than that, the only change to my turntable has been a new Dynavector TKR cartridge, to replace a worn XX2 MkII.
I rate Naim and it’s products very highly. But I have to be honest and open about my experience with the Solstice as it just might just help one or two fellow owners with future purchase decisions.
This is the type of forum info that has historically helped me.
Steve!
It would be great if you can ask him to explain the considerations behind the decision to allow the platter to ’bounce’ vertically (on its magnetic suspension) in relation to the arm pillar.
I successfully fitted a ARO1 counterweight to my Solstice and was able to achieve the correct downforce on a Lyra Kleos SL. Not sure how many of these are available used, but I would not be hard for an experienced machine shop to manufacture a run of these for Solstice owners.
Who’s making aftermarket LP12 parts these days? I think Tiger Paw is no longer in business.
@110dB I think it would be a good idea for Naim to supply an alternate counterweight for Solstice owners. What can be done at the factory to make this happen?
Chris, was this a standard ARO1 counterweight? Just asking because when I recalled that you had fitted one to your Solstice, Peter mentioned here that it would not fit. So a not entirely clear picture…
Naim would have to ask Clearaudio to investigate the possibility of supplying a weight/weights that would allow a wider range of cartridges to be used.
I read Peters findings and it’s a bit of a head scratcher. My Aro1 counterweight threaded onto the Solstice perfectly… I assumed it was a happy accident or the thread pitch was copied from the original.
Machining a lighter counterweight is not rocket science. A fairly straightforward project. Naim or aftermarket could easily produce this.
