In the screenshot provided the A-Z alpha sort is one, which is forcing them to list not in the sequence as intended.
Primarily VRT/RTBF/BRF is the national broadcasters for the country view.
The other two stations (The Jazz Groove and 2XS Radio) have special promotions with us (better quality streams and streams that are not on other radio services) and in return we give them higher visibility by linking to them on the radio hope page.
Regarding search, as you are using a NAC272 that product doesnât support global search of radio. It only supports filter in list. So it will find things that match in the current view. Hence filtering on BBC will return 0 results in that view.
RE: Products that are on the current day platform that we introduced in 2017:
Uniti Atom
Uniti Atom HE
Uniti Star
Uniti Nova
Uniti Nova PE
NDX2
ND5XS2
ND555
NSC222
NSS333
Muso2
Muso Qb2
Naim CI102
Focal Diva Utopia
Regarding the custom presets working, I think you might be a lucky guy and a Vtuner bug has worked out for you. Primarily VTuner introduced a bug where instead of virtualising the URL (so it went to the VTuner domain and the actual station stream URL was resolved), the physical URL was returned and this ends up stored in the preset. The problem now is that there is no way to ever update this preset.
Unless the station is a membership only stream, this thread is a way to ask to have stations that are not in the directory to be added.
