I have uniti nova connected to MA silver 300s and it has been working well for over 6 years now after I fixed the boom effect, recently I realise that nova is hot to touch even in standby mode.
I had usb drive connected to it so removed it and still nova temp is high.
It cools down only when unplugged.
Is something wrong with the hardware, is 6 years too long for this device and does it need servicing?
Thereâs a lot inside the Nova in a small space, and the ICs can run very warm indeed. The case work is there to provide passive cooling so a warm to moderately hot casework is not unusual.
Thank Richard! Iâm relieved to know this is usual , just bit confused why I didnât see this issue before but knowing this doesnât harm the electronics is good enough for me .
Only difference in my setup was making it âserverâ and attach usb drive. I have removed the usb drive , and may be will turn off the server mode as well.
You donât need server mode turned on to access the contents of a USB drive via the server input, so turning it off wonât be a problem unless you use it to allow other streamers in your home to access the same USB drive.
Server mode stops the Nova from powering down when you put it in standby mode, which is why it will stay warm (or even hot!) when not in use.
My Nova randomly runs hot, there is no rhyme or reason that I can see as to when it does and when it doesnât. And I have tried to find an explanation. But I asked Naim about it during beta testing Nova firmware a couple of years ago and was told not to worry about it.
But I do always put it into standby when I go to bed. Sometimes itâs hot before I put it in standby and sometimes itâs not.
I imagine a rescan is only done when the Nova first boots up. The only way to know for sure is to try it. The Nova automatic standby works really well and is ideal if you want to avoid wasting power.
Note that if you enable server mode, or if you leave a USB drive attached, the Nova will not power down when it goes into network standby mode, so the main PSU remains powered up. (Some people do this on purpose so that performance is not affected when you first start playing and the unit is cold.)
If you want to ensure that the Nova is cool and energy efficient, you either need to disable server mode and remove USB drives, or you need to use âDeep Sleepâ mode instead of âNetwork Standbyâ.
Added information: âDeep Sleepâ is achieved by long-press (couple of seconds) in the power button at the front of the unit. Also only button to power it on again (it wonât react to app or remote).
Itâs effectively âsoft offâ, I.e. the unit shuts down except the button can still power it up again. This means complete boot sequence (like after loosing power), hence it takes a while for the unit to be back in operation.
