Hi @Adikt
Good to see the Aria made a positive impression.
Genuinely think it’s a fine phono stage and will carry you forward with further Rega options yet.
Few thought that might help with your OP….
From RP6 / P6
From a stock RP6, we went on a journey and over time added NEO psu, also Exact to Ania to Ania Pro. Upgrading from MM phono to Aria too. At that point, our feeling was the RP6 platform was max’d out. Maybe you have arrived at a similar thought process with your P6.
P8 or P10 would be a logical next step. Maybe carry the Ania Pro and Aria over to next TT, to make the transition easier. It’s definitely a postive step forward, with SQ. So, would encourage this idea.
However, my experience here is a more significant progression will only be achieved - with P8/P10 - when you go to Apheta 3 or Aphelion 2. At which point, moving to P8 or P10 becomes truly worthwhile. Which is fine. Just do it in stages and enjoy the journey along the way.
In the same situation, we did a different thing. But only because my best mate ( my lovely wife ) and myself are not fond of the more recent Rega skeletal design philosophy. So much so, would maybe seek out an older style RP8 or RP10 as alternative. Anyway…
Another route forward is maybe with a different deck?
Faced with upgrading from RP6 to higher Rega decks, we choose to improve our original LP12 instead. Moving from a standard basic LP12 to a version of Linn’s Selekt level. At the time - in 2020-21 - it was a similar budget.
Rega Aria
Circling back to your Aria…
Had the opportunity to audition a new Rega Naia recently, fitted with Apheion 2 and c/w Aria phono. This was impressive. It sounded to me one of the best TT experiences to date. Obviously, an Aura was better. But my point is the Aria is a very capable phono, that might go with you to at least P8 and Apheta 3.
SN3 + HCDR
Using a SN3, we thought the addition of a HCDR was a very worthwhile improvement. Obviously, the whole system benefits and both sources. So, maybe just decide on priorities and do this, either now or later.
(Note : Caveat, forum opinion on adding a HC to a SN is divided, so maybe best to audition this step first, if you get this chance).
Separately, we have a Nait XS2, which we use with a HC2, also a great upgrade, so don’t rule out earlier HC2 units. Maybe not as bigger step, but equally, should be a lower cost too.
A third way ?
Looking at your profile, your current system, thinking about options…
So, another option forward is to add a psu to your digital sources ND5 XS2 → nDAC.
Naim psu options for nDAC are XPS, XPS DR, 555PS and 555PS DR.
So, for example, a nice XPS DR for the nDAC would take your digital source to next level.
In summary, from current system, maybe options might be
- Analogue source
From P6 to P8/10, carry Ania Pro & Aria forward.
Later, move to Alpheta 3 or Alphelion 2.
Steps of your choice and pace, budget depending.
- Digital source
Adding a psu, say XPS DR, to your nDAC.
As budget allows.
- Amplifier / controller
Add either HC2 or HCDR to existing SN2
As budget allows.
In any order, according to your priorities and preferences, as budget allows.
Often admired your system ( which was very similar to our system as recently as 2023-24 ), also your room and that view. So, wish you luck with your journey.
Best wishes
R
edit : one additional thought - if you haven’t already looked at this - maybe think about interconnects between nDAC and Aria to the SN2. To eek out a little more goodness, add a HiLine DIN to DIN between nDAC and SN2. However, not convinced a HiLine is such an obvious improvement for analogue sources. For Aria to SN2, more inclined to use Linn Black or better Linn Silver RCA to RCA.
