You’ll need the link plug in place if not using a Napsc. But the Napsc is a really good idea, as the 202 sounds considerably more natural with one in place.
Thanks,
Dave
Don’t discount using your 150x as the power supply for whichever pre-amp you get. IMO it is comparable to using a Flatcap - it is only significantly bettered once you go to a Hicap.
An 82 or 282 would come with a NAPSC and you’d be up and running
