What do you mean Second link plug?
You should have one of the two link plugs fitted (link 2), as the Flatcap will be powering via Upgrade 1.
You need a link plug connected to the link 2 socket, like this.
The other thing you could do is to use two Snaic 5 leads and connect the Flatcap to both upgrade 1 and upgrade 2.
Remember that the 282 really needs a Hicap, rather than a Flatcap.
OK boys, thanks for help! Now I will connect the second power output of Flatcap XS to Upgrade2 socket. I will reportâŚ
It is working now! I have two 5pin cables and I am playing music just now.
The sound is very different from XS2! How you said, it is another level from the first moment.
Thank you all!!!
I will start to find Hicap and I need link plug! Isn´t it?
I will contact seller Criterion Audio from Cambridge to complete deliveryâŚ
Thatâs exactly right. Or get a Supercap, in which case you wonât need the link plug!
