The Supercap is a recent (used) upgrade and initially everything was great. I then swapped out the non-naim 5-pin cables for Naim snaic’s. Since then I’m not getting sound from any source except cd when I can hear it faintly when I turn the volume to 2 o’clock position. I’ve borrowed a snaic that I know works so that isn’t the problem.
Anyone any idea where the issue might lie?
Check all the plugs are in properly. I remember when I added the 300dr to my setup one of the Burndys wasn’t seated properly and this gave me similar problems.
Spud
As it was working with the previous cables, do you have the two SNAIC5 cables between the Supercap and 282 connected to the right sockets ?
282 upgrade 1 socket to Supercap socket 1
282 upgrade 2 socket to Supercap socket 2
You could also try just one SNAIC5 between 282 and Supercap. Link plug back in link 2 socket on the 282 and 282 upgrade 1 connected to Supercap socket 1
For some reason I have two stereo xlrs between my 52 and 135s rather than mono. I therefore never have this problem. Although I have ended up with the channels the wrong way round in the past. A quick blast of Stairway to heaven intro helps confirm they are the right way round.
It’s not going to damage anything using stereo DIN to XLR cables, instead of the ‘handed’ mono versions, There may be a slight SQ disadvantage as you have an unused channel in each stereo cable so an increased level of capacitive coupling to the unused channel.
