Just purchased a XS3 Integrated Amp used.Powered it up but only getting faint sound in one channel with a intermittent “ticking” sound.Then it switches inputs from phono to tuner or cd to tuner.Switches inputs whether I select by front panel or remote.Tried it with both 5pin DIN or RCA cabling.Box and amp showed no visible damage from shipping.Has anyone else experienced a problem like this?
From a dealer?
I would hazard a guess at faulty source selection relays.
Just in case, make sure the power iec plug is fully inserted.
Also try a reset, same method as here;
