You need two cables!
For me the final decision would depend largely on the final position of the sub relative to the amp and speakers. I would do whichever gives you the neatest cable run and avoids doorways, fireplaces etc.
I did that once, I just split open the sheath to the stock REL cable and ran it between the speakers: one lead to one speaker, the other two leads to the other speaker. You donât need two cables for a single sub though.
In the case of one sub, itâs probably easier to use a REL Baseline Blue for Naim. Iâm just turned off by the cost of it.
Youâre right. Also the stackable plugs are crap - a really poor connection into the amp
I would chop them off and solder them onto the same plugs as your main speaker cables. Once youâre sure youâve got the position right, of course.
You run two sets of cables to a single sub. You can just take from each positive and one negative. The nice thing here is that itâs just a reference signal so no need for fancy cabling. QED 79 strand or similar will do just fine (i.e. really cheap).
I would use something even thinner than that. Bell wire would probably do it. I used some Chord Sarsen as my dealer happened to have some.
You would need to get hold of a Neutrik plug for a Rel sub though.
Yes, we used to use Chord Leyline at the factory.
That was presumably for an N-Sub though, in which case youâd have been using regular Naim plugs instead of the Neutrik?
Yes, that was for an N-Sub using regular Naim plugs. Neutrik required for a REL.
This is all getting beyond my expertise level. I can teach you how to fly, but I donât know how to wire a Neutrik plug
This where your REL dealer comes to the rescue. Should be easy and all in a days work for them.
Neither do I, but as I said earlier, a competent dealer or cable supplier who understands whatâs required will be able to make up a suitable cable, and it should cost a great deal less than a Bassline Blue. Give designacable(dot)com a call, they will be able to do it.
If you view my profile, youâll see that Iâve been a pilot for over 42 years⌠I may not be a HiFi expert, but I know which way is up on an ADI. And my profile picture is a younger version of meâŚ
