As requested by @Sinewave, here are a few photos of my ‘refurbished’ SCM 12’s originally purchased over 20 years ago.
They are already pictured in this thread but not for a while. I’ve recently upgraded the signal path from the SuperCap to the NAP 250 with a new Van Damme DIN - XLR interconnect. £30 from a from a well-known auction site. An immediate improvement in detail against the original Naim NA-51. I also added Tellurium Q Black II jumpers replacing the ATC brass links. Again, a little more top-end detail and sparkle.
Over the last few years though, I’ve had to adjust the balance of the pre-amp more and more, and after having the 282, NAPSC, SuperCap and 250 serviced by Darren at Class A, I was assured the problem lay with the speakers.
I spoke to Ben Lilly from ATC at the Bristol Hifi Show last month about the problem. He suggested that the crossovers and bass drivers would all be fine, but the ferrofluid contained in the tweeters would certainly be drying out, creating a db drop. He offered to send out new tweeters but said that their stock replacement item had a slightly different rear heat sink which would require some alteration to the front baffle; a job I do not have the skills to accomplish. He made a phone call back the the factory for me and confirmed an off-the-shelf replacement from the company that bought Vifa Drivers. Willy’s Hifi delivered a matched pair this week for £59 plus VAT. Easy to swap out.
On the first power-up, they sounded a little harsh and the bass had seemed to have washed off a little. But over the last few days and after running the speakers at continuous high volume, the frequency response has evened out and the top end is becoming softer and more detailed. I’m told to expect the SQ to improve over the next few hundred hours.
New 56-06 from Tymphany being fitted (thankfully push connectors so no soldering)
The original drivers removed, made by Vifa Denmark
A great little project, not costing the earth and the SCM12s restored to out-of-the-box condition. And they sound great. Naim and ATC do have a natural synergy.
The medium future will be to replace a lot of my kit basing the new system around ATC SCM40As. I’ll be auditioning the NSC222, Linn, an Auralic streaming pre-amp, pre-amp/DAC combos from Chord and, ATCs own CA-2 and SCA-2. My gold-plated system would be a one-box solution. So all change over the next year or two.
I thought the new Chord integrated amp fed by a Qutest and M Scaler and driving the SCM40s was the star of Bristol '24. It easily bettered Naim’s, Dynaudio’s and even ATC’s demo setup. But I do think Chord were lucky with their room allocation. This is of course my opinion!
Daz
