As noted, I did the firmware update and did a factory reset, which certainly seemed to help, if not fix it completely. Then took it off to SE26 intending to “annoy” the parakeets in Daughter#2’s garden.
Not a bl00dy one! Cats, squirrels, fox…..but no parakeets. So I went out with the RF28mm to the Brunel museum in Rotherhithe and then over to the Maritime museum in Greenwich.
A novelty but I think may be quite fun. It’s the ’Pro’ version of a screen-less digital camera, aimed at kids going to Camp in the U.S. that have screen bans.
Like a digital version of a disposable point and click, only keepable. Limited user variables are flash settings (off, ‘selfie’ and ‘group’) and filters (standard, 1, 2 and b&w).
No immediate checking of your screen post shot. And a bit cheaper than an M11-D for same experience.
Looks metal, isn’t. Straight through plastic viewfinder. Teeny tiny sensor.
Might stick a level on it as the plastic viewfinder is quite distorted. This may be amplified by my varifocals but that would also help with shooting from the waist, being so light it’s hard to judge if it’s level…
