Yes, so is mine, but Douglas seemed to imply that he had a Urika mounted in a separate black box, which I assume is actually an Akurate Radikal.
Antz answered my concern about the higher mass of the Stiletto with the Urika baseboard. I assume if one were to go for the TA baseboard it wouldn’t be possible to use the Urika phono amplifier - unless it can be removed from the base. Still, it’s not really a concern for me with my plinth and top plate combination. Well, not yet anyway
Here’s my much loved LP12. I bought on eBay several years ago with valhalla power supply and the bearings on the Akito were shot. I got it serviced and changed the power supply to a Lingo 1 which Darran at Class A has since serviced. The Akito tonearm was sent off to Audio Origami who repaired both sets of bearings, fitted a metal plate to stiffen the arm (pictured) and rewired it. Since then changed to Cirkus and Kore and upgraded cartridge to Dynavector 10X5. Graham Slee Reflex M phono stage. Am very happy with it. Looking at Karousel and Radikal at some point and maybe Ekos later down the line. Want to get value from the tonearm repairs before going on to an Ekos!
I think it looks rather good, and nicer than the old Pro-ject or Jelco offering. In it’s styling there are some echoes of a past tonearm that was a wonderful Sondek partner - the Syrinx PU2.
“Is the sticky uppy bit the bias? I wonder how it works.”
Majik?
Seriously, Linn don’t give anything away, they don’t seem to mention it in their data sheets, but as the Krane is from Clearaudio, I think it is magnets.
Rega arms are dynamically balanced, using a spring, whereas the Krane is statically balanced. I just wonder that the bit on the right does, and how it does it.
