After the previous LP12 shown, a relief to see the sort of LP 12 I would like to own
A few years ago I started a thread, asking for turntable suggestions for my SN3 (with MM phono stage) ie specifically not wanting additional boxes. Several people suggested an LP12 which I’d not considered for my shortlist. I think a Linn Sondek is the most beautiful looking piece of hifi - and after hearing how good they can sound - my mind was made up. My set up is: SN3, NDX2, LP12 through Twenty5.23s.
Thanks to Peter @Cymbiosis for sorting me out with a Karousel, L4, Kore, Ittok with AT VM750 SH.
It’s sounding breathtakingly good isolated on a Vulkan wall bracket.
Simple and stunning. I could not be happier or more grateful.
Nicely done
Like that set up - a lot!
Thanks @YetiZone I had an AR EB101 which was a decent turntable, but which in a hasty moment I gave to charity many years ago, assuming I’d never return to vinyl.
I am amazed at how good the LP12 is sounding. (Especially albums recorded in the 80s and 90s that don’t sound nearly as good digitally). I’m putting it down to being on a quality dedicated wall bracket, the quality of set up by Peter and the synergy with amp and speakers.
Thank you for the photos of the rebuild.
Been wondering what to do with mine.
Still wondering.
Currently using a Krystal
If go over to “Troika anyone?”, there are lots of forum members that have shared their thoughts about their Troika’s, (including rebuilt Troika), compared to other cartridges. Some are Krystal users.
Also, on this thread “Show is your Sondek” this same discussion crops up. Maybe worth you reading about these other experiences.
Hope that helps?
Do share your thoughts?
Good luck.
KR
R
I had been getting on very nicely with a near top spec LP12 some four or so years ago when the Tangerine Audio Stiletto arrived at my local dealer.
A phone call suggesting I might like to hear it at home was greeted by me with interest and no more than that. When the two decks were swapped the transformation took only 30 seconds to hear and a positive itch in my wallet.
The Stiletto is considerably heavier but not enough th worry my Audio-Tek wall support. The weight of the plinth is the real key to its success making the Linn, to me, sound relativly coloured. By no means a cheap upgrade as it puts the modified TT into competition with other £30K TTs.
Just shows the almost endless possabilities from it.
Fully endorse the machining, fit and finish which are first class.
I am delighted with my deck, Stiletto on another level, the musical uplift is staggering
Enjoy
When the LP12 was introduced Ivor Tiefenbrun had his hierarchy starting from the TT, arm and then cartridge. A philosophy still true today.
@Douglas @Antz Not that I’m looking (yet!) to move away from my Woodsong plinth, but I seem to recall that Tangerine Audio manufactures a specific baseboard and was wondering if the extra mass of the Stiletto compromises the Urika baseboard in any way?
Not in my experience to be honest, I May well look at the TA base but the Urika and base has no problem with the support of the weight of Stiletto and Keel in my case
It certainly does not lack for any musical detail for sure
I am a fit and forget guy as my dealer does all the hard work and I just pay him!
The Stiletto was the most signilicant upgrade by Tangerine Audio. I went for their plinth bottom plate and three point triangular feet at a later date: Skorpion and Eklipse. TBH not a vast difference for me so for the cost involved you need to check it out. Once again very well made and excellent machining. All thanks to Derek and Mark.
Do you use the Urika? You don’t appear to have loaded your system details in your profile, so I can’t see. Thanks.
Sorry to be a bit vague. Its the usual Linn black box just a bit bigger than the Naim 32.
You mean you’ve had the Urika installed in a separate enclosure? Or are you using an alternative phono preamplifier? It’s normally mounted on the baseboard.
Normally Clive ??
I thought it always is / can’t operate otherwise
Maybe I’m wrong ?
Mine is on the baseboard
Hi Clive. You have given me the opportunity to look at my dealer invoices (ouch) and see exactly what I have got with my LP12.
The power supply is a Radikal hence nothing under the TT. This has had a recent upgrade in the past few months. So far I’ve not gone for it. Earlier this year I had a twin tower Fraim. Enough for the moment!
The LP12 feeds into a Superline, SuperCap and 552/500. Cartridge is Lyra Etna SL. Red Collaro mat.
Not enough hours in the day to fully enjoy it.
Ah thanks. If you have a Superline you won’t be using a Urika. BTW the Radikal can be used to power both the motor and the Urika, which is on the baseboard as shown in the picture.
