Show us Your Tablette 10
If he is he deserves to be knighted!
Absolutely not!! I’m not a miracle worker. That was Linn K20
Thanks for clarifying; if you did that with NACA5 I was going to ask which church you attend because it would obviously be the right one!
Using my Sigs with KS-1 cable these past weeks and they’re loving it.
I could never own them. They look far too much like Ascaris lumbricoides.
The Speakers or the cable??
Umm…
…and I need 5m lengths too!
Eeek…!
I do imagine that the KS-1 white cables go very nicely with your white Tab 10 speakers. How about a picture?
Curious as well to know more about KS1 - not for my original Titan T88’s - but rather a second system I will be putting together with 10 Signatures and a Uniti Atom. I am not able to use NACA5 (too thick).
Also looking to know if it is still best to use a minimum of 3.5 meters w/ Atom or if I can go shorter.
Best
Gregg
Hello out there in Tablette land
Have you got your Atom and Tab 10’s set up on their new shelves?
I can’t comment on length other than I use 2x5m. It ‘sounds’ great!
Signals may advise?
No unfortunately we will not be finished with construction until November. Still in the planning stages. The Tablettes are boxed and sitting at my mother in-laws house in Italy. I will either hunt out a pre loved Atom over there or buy one new. NACA5 is out of the question so KS-1 is of high interest.
They sure are purty
Lovely indeed!
No minimum required for the Atom I have used 3 different types and lengths thus far and can’t say I noticed any difference. Chord Clearway first as it was what I had before Naim needed them elsewhere so got NACA5 which I disliked for inflexibility and currently Witchhat N2 as it’s just more flexible than the horrid NACA5.
Hands down, my fave Proac finish - my old Tablette Sigs were the same.
Yes they were a lucky find. Someone in Italy upgraded to a pair of ProAc floor mounts and they became available. Nice start to a small system there. I am hoping with the completely sealed cabinet they will do well on a shelf right up against a rather thick several hundred year old wall.
I originally wanted to try the Atom HE with active bookshelves however EVERYTHING I looked at had a rear port. Not good right up against a wall!
My second system Stateside is a Naim 2 with my original ProAc SuperTablettes purchased in 1987.
