The soft camera brush is what I ended up using, thanks for that.
I read somewhere (a HiFi magazine I think) a few years ago; that Rega chose felt as it was the best material for decoupling from the platter. Cork, rubber etc are not as good for this. Some turntable manufacturers have a different perspective on coupling and decoupling. For example I understand that Michelle donāt like mats at all, preferring the direct contact with the platter. I am not sufficiently expert in this hobby so Iām open to good ideas but for the time being have stuck with the stock mat.
Missed a bit.
ā¦
Yeah! Properly manicured they areš
Looks as clean and sparkly as mine nowš
Herbieās does not recommend the standard āWay Excellent II Turntable Matā for ceramic platters, they have a different mat called āGrungebuster Turntable Matā for ceramic platters like in RP7/9/10, which one did you tried?
That doesnāt sound like itās promising Nirvana either.
That would make sense. Itās the Way Excellent. As I say, it works pretty well on the Thorens.
I have a Moo Mat!
Doomed to failure. It was posted (and removed) earlier.
Removedā¦
So what was under the cowl? Whatever it was, it looked enormousā¦
I only made it to the Linn bit of the deleted video!
All the rage in Texas amongst the Cadillac driving audiophile community
Rega RP10
From memory and not necessarily in this otder it was:
Gerrard 301
Thorens 160
Lenco 75
AR XA (or something like that)
Rega 300
Pioneer something or other belt drive
Technics 1200
Transcription (pre Michel but more or less the same).
Linn lp12
Brinkmann, forget which
And as above a Planar 10 under the cover.
Iād have though the original EMT 948 should have been in there judging by how much used ones go for.
Thanks.
So a skeleton not an oil rigā¦
One note on stylus cleaningāMr Clean Magic Eraser cut into rectangles. Best thing for cleaning the diamond Iāve used.
