SN2 vs SN3
As much as I believe that the SN2 is like this for your ears and preferences (I really do), I have to partially disagree here.
Agile, homogeneous and able to show dynamic nuances: yes.
Sensitive, refined and capable of presenting tonal nuances: not so much.
The SN2 isn’t bad with these, but there is more to be had. Anyway, I still like mine :grinning:
I agree, of course. Although, of course, it all depends on tastes and, above all, personal references; most of our planetary contemporaries would be more than blissful with a simple Dacia or Tata, while many will either never have enough or will not be happy with a high-end Mercedes.
For my part, completely satisfied with the sensitivity, refinement and capability of SN2 to present the tonal nuances; aware that more could still be reached, but feeling absolutely privileged to enjoy something that only a few have access to.
Cheers.
You are welcome.
For me, one of its best strengths is its great dynamic ability and its absolute bass control. It is also quite possible that the associated speakers make a difference; with the floorstanders I had previously, my previous Exposure combo sounded brilliant, while the same Exposure combo with the K6 was unbearably warm and colored; and the K6, which from what I see are very balanced and very complete in the entire frequency range to let you listen to the electronics and the rest of the chain, with the SN2 are in their sauce, with phenomenal and very articulated bass.
When I had an SN2 I did not notice great improvement with time/run in but then again, it sounded so good out of the box that it didn’t Need to.
My SN3 is a decent improvement over the SN2 - transients seem better controlled. The improvement in transients manifests itself as better control. The bass sounds a little bit lighter which probably means the notes start and stop a bit quicker.
The differences are by no means night and day but are noticeable.
I used Neat Motive SX1 speakers with both and prefer the SN3’s lighter touch on the bass. As the volume increases so does the punch. An excellent amp in my humble opinion!
I assume that what you write is a personal experience of a sn2 owner but it is not clear to me if you have an ext psu or not. Psu is a game changer in naim config and what you describe as not strong point let me suppose that ext psu is not in your config
Hi,
you guessed right, these are my impressions after listening and owning a bare SN2 for three or four years. The SN2 is already a better amplifier than several older ones when it comes to tonal resolution and quite colorful. But there is more to be had in this regard. The ones I know to be better can’t match the SN2 in other regions. As often, know what’s important to you and decide accordingly.
Agree but imho tonal resolution and richer color rendition are preamp game and this is why I think that final verdict has to come after hicap audition. It is a game changer in terms of delicacy, low end control, tonal and spatial resolution
Hi Piebla, my observations described in one of my previous posts when switching pre amps from the one in sn2 and the one in dac v1, lead to a contradiction with your assumptions – when I use v1’s pre amp and sn2 in av bypass, resolution is reduced, but somehow tones are richer. So I guess these might not be characteristics corresponding solely to a pre amp. Again, I may be wrong, due to the early days of my sn2 burn in period though.
I found my SN2 to be rather sensitive to the power it gets fed. I recently upgraded my power cord from a Shunyata Delta EF to a Shunyata Alpha EF the SN2 just keeps getting better. Everything I’ve done has improved the system… Power block, speaker cables so far the weak link hasn’t been the SN2
next step, the Betha?
What’s a “betha” ?
sorry, bad joke and bad written: alpha beta gamma…
Sigma is next in the Shunyata line: Delta, Alpha, Sigma.
you may be right Daniel, but personally i was joking. I don’t know nothing about the range of shunyata cables. It was Delta, then Alpha, so i wrote Beta…
This makes a lot of sense. Maybe time to question my aversion to even more black boxes…
@frenchrooster you should try one, Alpha on your amp?
forgive my bad joke Rick. I was not criticizing really shunyata cables.
For now i have all kharma power cables and am satisfied.
It’s all good
Another review
https://www.naimaudio.com/sites/default/files/Naim%20Supernait%20%203%20interview.pdf
…thanks for the link, a wonderful review for the SN3.
