Snaics between 282 and SCDR
I have an SCDR incoming to replace a Hi-Cap DR on my 282. As only one of the two Snaics between SCDR and 282 carries audio, does the quality/age of the power-only one make a difference? And if I acquire another Naim one to use for power, which of the two below (taken from How to identify SNAICs and Interconnects ) is the more current version - top or bottom?
Apologies is this is against the forum rules to discuss.
It’s certainly against the rules to discuss non-Naim Snaics. You should use two genuine Naim Snaic5s.
Ok thanks, noted and edited. Although do you know which of the two in the above photo is the later version?
The top one is the current one I believe.
Great, thank you.
The top one
