Hi
I have a Naim Nait xs2 and stax L 700 and 006 energiser which works fine
Have been looking at going to 82/hicap /250
What connection do I use for line out into the energiser please I couldn’t see an av out (?)
Many Thanks for any advice
Tony
I’m not sure what an energiser is.
From memory the only out on the 82 is on the tape loop. I think it may have two that are input/output. I’m not sure if that’s what you need
Just use a suitable lead connected to the output pins of socket 4, 5 or 6.
Thats because there isn’t one… But there are sockets which have outputs on them…!
You’ll use one of the Tape loop outputs on the NAC82. You’ll need a custom DIN - RCA interconnect as a regular DIN5-RCA won’t work (you need the REC pins of the DIN connected instead of PLAY)
See the FAQ here;
Thanks everyone
I am currently using a flashback lead between the xs2 and energiser which works fine
Naim Style 5 Pin Ring -
Locking DIN Plug - 2 -
Phono/RCA Plugs Headphone -
Amp / Record Out Performance-
Cable
I assume this will work ok
That will be fine.
If it’s working with the NAIT XS2 then it’ll be fine with the NAC82.
Great
It’s the same cable that Dave from Fkashback (RIP) made for me that I used between an 82 (now replaced by a 52) and a Stax SRDX-Pro.
