After a while struggling with the router installed by the ISP when I upgrated the service to 500Mb, finally getting a new brand of router that works well in Tidal, I came with other problem, already posted here without a solution then.
Trying to play certain TIDAL albums in my Hiqute2, I get errorr “Error: Failed to get Tidal Album: 20559873”. Same album (Billy Joel, Songs in the attic) plays without problems in the Windows app.
Search anything in the (certain adjectives apply, like erratic) Android app is almost impossible, so I normally search in the Windows App, make the albums Favorites, and after a while they appear in the Android App in my Samsung A5.
I suspect that the NAIM app keeps some pointers for the albums that are not updated when you unmake and then remake them favorites again, but the problem is I don´t know how to get away of this situation.
Thks in advance for your help.
BTW: My repaired CDX2 came from Salisbury to… the Portuguese customs… More days and paperwork to do, maybe in the summer gets here…
Luis
