Currently playing LP12 through a Uniti Star. I am considering buying the NAP 250 DR.
I am limited for space so can I sit the Star on top of the power amp, or is this a complete no no ?
Its not ideal - and its not⌠encouraged⌠ButâŚ
Donât do it if you can avoid
My first bit of Naim kit was a CD5 with a Nait 5i amp on top. It worked fine; I remember asking the dealer about it and his advice was that itâll be fine that way round, but putting the amp underneath the CD player could cause issues at higher volumes when the heat has less opportunity to dissipate.
Thought as much, will have to buy a new shelf for the rack then!
A Star and a 250 is not something Iâd go for. The Star isnât really up to fronting a 250, which deserves a lot more. Iâd suggest that an NDX2 and SN3 would be a lot better, and would mean that the Linnâs input remains in the analogue domain.
That wasnât the question HH but you are right. I can see little point in vinyl no matter how good the TT is if the electronics turn the signal digital and back again. That said thatâs exactly what Linn do in an all Linn system.
That would align with NaimLoreâŚ
Short term though, a dispensation could be conferredâŚ
I have this combination and I think there needs to be a separation between the two. I have my virgin box on the shelf between them and it works well. Also, you will need to get your dealer to make up a lead for you as the Star output is phonos and the signal lead that comes with the 250 is terminated in a din plug.
As for whether it is wise to pair the Star with a 250, I am in agreement with @hungryhalibut to a large extent, as an endpoint a Star and 250 is not an ideal combination, fine as a step along the way, as it is in my case. That being said I do believe the Star preamp/streamer section does benefit from the power amp not being used and part of the sonic uplift is due to this.
Itâs an XLR on the 250, but yes, you would need to get a slightly non-standard lead made up.
I agree than NDX2/Supernait is likely to be a better setup, unkess the 250 is a stepping stone to a separates system.
Thanks for your response. Answers the question and I agree with the âstep along the wayâ, but also the âaffordableâ step along the way.
I have a large CD collection and large vinyl collection. The Uniti Star was the coverall for me and an entry into the world of Naim, and appears a very capable amp in its own right. Sound quality from my LP12 through an EAR Phonobox is exceptional to my ear.
I want to do further upgrades to the turntable and have heard the NAP 250 DR with a Star and was impressed no end.
There seems to be a lot of âyou donât want to do thatâ on here!
Trying to save you possible disappointment - and moneyâŚ
What you are proposing, while possible, is not the conventional way to go. A 250 is a very capable amp, which deserves a very good feed to it. Normally a 282 or higherâŚ
YMMV, as always.
It is an XLR on the 250 but the Star has phono output sockets rather than a din.
Yes, that was my point. The post I was replying to seems to have been deleted: it incorrectly said DIN instead of XLR.
Adding a 250 would be a sensible thing to do if you are later going to move to an NDX2, 282 and Hicap DR. But are you? If not, itâs not a good idea. Rest assured that I say this to be helpful, not just to be awkward. If you donât want helpful advice perhaps you can specify that in your original post, then Iâd avoid wasting my time in responding.
Why isnât it a good idea? It will surely still be an improvement regardless of other changes.
I think this might have been covered before
Perhaps if you had answered my original question and not offered unwanted advice then you wouldnât have wasted your time!
It wonât do any harm from an electrical standpoint.
It may not be optimal, however it will probably sound bl00dy good!
Just do it.
