Hi, I’ve just plugged in Superline today and I tried to find info but without success, so here’s the question. Are capacitance plugs hot swappable or I need to unplug the snaic (switch off the preamp) to replace it?
I would like to experiment a bit, but not sure about the steps.
But never do without either muting, selecting a different input, turning volume control to zero or turning off the power amp - to swap with it connected live to the speakers risks speaker damage.
I swap plugs on the loading and cap sockets of my Superline all the time. I just hit mute on the preamp when I do. I have two Z-Plugs (453R and 470R) and use both the load and cap ports to combine them sometime for different values (something like 470R + 453R → 225R).
You do not need to turn off power and/or remove cables to swap out load/cap DIN plugs. Just mute or change the input.
TBH: I have changed load/cap plugs with muting and it never made any noise anyway. I just mute normally out of an abundance of caution.
Never had noise through speakers from swapping loading plugs, all I do is lift the stylus.
If the superline’s in the middle of the Fraim shelf getting the plug out of the cap socket can be a bugger, you can’t get a thumb on it and two fingers don’t have much grip so it takes a lot of wiggling.
Just be careful if you haven’t done up the SNAIC collar as the plugs can be a bit tricky to remove and replace thanks to fitting quite tightly and the movement of the sprung mass-loaded main board, which might dislodge the SNAIC, so best to mute or switch to a different input while you do it.
It actually serves a decent purpose for me. With my Lyra Atlas and Dynvector XV-1s I mostly run them with their single plug values, but for some classical music that is recorded too hot/bright and sounds edgy (i.e. 70s/80s DGs), adding the second plug to increase loading helps.
On the Boulder I plan to get as a replacement, I will use 225R for the Lyra and DV, and 100R for the Lyra mono, and that is suitable for just about everything, and I can change to 100R for those problem classical recordings.
