System Pics 2019
Hi BF,
I use Superline with Supercap together with an Ortofon Cadenza Bronze. Originally I used an inexpensive Graham Slee Reflex Slee phono stage which also gave good results.
Looks like a lovely peaceful room that people enjoy living in.
Without the Allaes in the shot
what’s between the speakers? a digital chimney? a future aquarium?
Centre speaker, new tech haven’t you seen these before
seriously, just decoration? original if it’s that
It’s a Bioethanol fire, looks good when fired up and occasionally place candles in the opening.
thanks, it’s make more sense. I didn’t know of it , is there some danger with it? does it smells good?
Naked flame but no danger, outputs about 2k of heat and gives off no odour.
you can install that easily, or you need to have a chimney place before, with that ( the picture).
you need that?
The reason we opted for a Bioethanol fireplace is that no flue is required.
very good, i will investigate for the next winter.
a last question: where the gaz disappear ? it requires a special installation?
Bioethanol fumes are mostly water and a little carbon dioxide, completely safe (except the naked flame) and you can install these yourself.
CE9EEFC7-C738-42BB-8E70-B45C7BAC7A84-4042-000003269E9BC900
Was this your system installed in the HMS Titanic ?
no, you are completely wrong TJ. The system is in his private jet, and photo was taken during a looping. :clown_face:
Congratulations on the SL2s I’ve been reading with interest on the other forum about these and they look great in your room.
Thanks Bob, took some time setting up probably 3 hours in total but it’s worth the effort as the end result is stunning.
Lovely neat set up HiFiman. Is that D-Line trunking above and below your skirting board, hiding the cables?
Have used it myself in the past.
