Looks lovely. Surmising from your question about whether I was going to DR my 552/500 that yours is not. It’s an amazing bit of kit even without DR!
Keep the 500 mains plug as far away from everything else as you can. I just have 5 double sockets so I left the second on empty. A worthwhile tweak. You may have a separate mains block, in which case put the 500 in the wall socket.
one key suggestion in my experience is to find some lint either from the floor or your belly button, roll it up, and stuff it in the LED light hole on the front of the Radikal. the blue light is, as my wife said, “brutal”.
@Koko61, Is that a Hi-fi Racks rack? If so, wouldn’t it be better for you get an extra shelf to separate the two boxes on the bottom shelf? You can get shorter legs to keep your rack the same height. 150mm long legs are long enough and you will have enough space for isolation plinths or Naim glass in the future.
It’s a cracking little system and I think you have every right to be very pleased, but I would try and add an extra shelf. Love the speakers , not a brand you see that often on these pages.
It is a self-built rack. I did it when I still hadn’t bought the flatcap 2. The speakers are the Stirling MS-88, exactly the same as the Rogers ls3 / 5th 60th anniversary.
Thank you.
