There seems to be a tendency for some speakers manufacturers to polish so finely…they look like plastic?
Ah, yes, this is especially true of polyester lacquer, as used on top grade pianos and posh car interiors. ART use an acrylic lacquer which is much less labour intensive (and hence less expensive) to apply.
I don’t know really… I fall asleep much more quickly
Well that may be expensive for a chair, but its cheap for an upgrade to get an up tic in SQ.
Please sent me I will appreciate … thx
I will group all the orders from here and then send them with my Boeing jet. Please take into consideration that some airports are closed. We will make all the necessary to satisfy your needs.
Do you have a boat you can ship it through Mediterranean Sea …Lol
You can chuck mine out the door with a parachute on. Thanks
You don’t like it, if I understood well. However personally I prefer my sofa …even if I find the style of the chair nice.
No no. I like it lots. Just trying to save you time by having to land your 747. Will help with the social distancing too.
I like the CD rack!
My CD rack. There are 3 in the back and 2 sliding ones in the front. Quite a lot of CDs in a reasonably compact space. I lifted the idea from a bookstore I saw ages ago. Worked out quite well.
Cd storage. Wow!
CD storage. No problems !!!
It looks like the couch is Stressless too; I have a little Stressless 2-seat couch. Great products.
Hello Bart
Can you post a pic of the 3 seat couch by Stressless. Thanks
Unfortunately the 2-seat couch isn’t StressLess. We bought it from a local furniture shop.
StressLess products are indeed great. Comparing to the previous one, this chair is particularly comfortable. The stand and the internal suspension makes a splendidly comfortable seat.
The cosiness of the seat and the music makes a nice contrast after a day climbing outdoors in spartiate conditions.
