The latest pic taken just now from my system. I’ve replaced the Marantz HD DAC1 for a TEAC NT-505 streamer dac. Although i mainly use it as a DAC (i like the ui from jriver)
Furthermore i’ve placed the speakers a bit higher so that the tweeter is on ear hight.
There’s felt on the floor, 2 stoeptegels, then 1 cm rubber and the the top stone made from belgian bluestone. I had my eyes on a ND5XS2 but i’ve come to realise that i’m used to and fond of selecting music the way i do on the screen to the left.
The TEAC however does an excellent job, so it will suit my needs for now anyway.
Heavens, I’m losing my grip. My mind was distracted by thoughts that those speakers look pretty good in the walnut veneer. This quantum shift rather threw me off balance. Actually, the issue is that the shelf is not upside down, rather than being upside down. Of course, in the case of the bottom shelf, upside down is the right way up.
That’s right, indeed. But considering the short distance between the listening position and the back wall, diffusion isn’t the best choice to make. And the fact that the back wall is made of windows, diffusers like those used on the front wall are far too heavy to be installed.
I chose the “black hole” option, which means: 6 big GIK Monster Bass Traps and a highly absorbing curtain. Reflection from the back wall is reduced to the minimum from 60-65Hz up to 5kHz (or more).
The diffusers between the speakers provide a correct RT60, while keeping some liveness to the room.
The whole thing is of course a compromise. But the measured result is pretty ok. In fact, I’m quite proud of it.
My subjective reference is a pair of Magico M2 driven by a Soulution 711 in a 120 square meters room.
The acoustic treatment brought me some of that airiness, details and stereo imaging.
And, of course, I never do final subjective testing myself. My unbiased beta tester is my wife
OK thanks for explanation, anyway where did you get your diffuser behind your speakers they look good, and was the gik impression panel’s which I am considering an option for you behind your speakers.?
C
3 x : Vicoustic Multifuser DC2 white (cute/adjusted)
E
16 x : Vicoustic Cinema Round Premium
A
2 x : GIK Monster Bass Traps - Thickness 28cm
B
2 x : GIK Monster Bass Traps -Thickness 20cm
D
4 x : GIK Monster Bass Traps with Membrane Tech
Thickness 17cm + 2,5 cm air gap.
F+G
4 x : Vicoustic Cinema Round Premium
Streamer Pro – Acoustic veil
L
6 x : GIK Monster Bass Traps - Thickness 17cm
Not on the pictures
1 x : GIK Monster Bass Traps ( 180cm x 55cm) - Thickness 17cm
I wanted to keep as plain as possible. I chose the Abodo White fabric option (which in fact isn’t really white). The printed option can be hazardous. Once one gets bored of the printing…
Thanks for details it does make a huge difference to sound, which a lot of people don’t recognise for some reason thanks again your room looks fantastic.
@Thomas I guess the logical conclusion is that my setup is massively sub-optimal since I have absolutely none of these contraptions in my living room and probably never will have. Can only imagine how nice your room must sound…
I would state it differently, the room interaction is kept to a minimum. Which means more direct sound from the speakers and less reflexions from the walls.
The system sounds really fantastic, to my ears. But also to my wife’s and friend’s.
Need to figure out the logistics of where to put my step-up and dac. AQVOX switch made a nice improvement on other side of room with its own conditioner which also powers my media server and NAS.
In this time of Covid 19 i finally reorganized main system with two new Fraim bases and leve whichl i had already at home for a few months.
System one, i also rearranged and cleaned the bookshelf and tied up the desk.
