System Pics 2021
The silver also looks very good… :+1:
Looks a love piece of kit.
The more I listen, the better it gets…or is that the Springbank… :tumbler_glass:
Maybe both. :tumbler_glass:
I was going to make the mistake of asking if you had considered a Nova instead of choosing this one.
but then it went to research (learn) what this system was really about.
Understood. :sunglasses::+1:
Someone here also mistook the Linn Klimax DSM Organik (aka Linn DSM/3) for a Naim Atom clone!
Similar isn’t the same.
(Although it’s not even similar )
:wink:
It`s very expensive.like price ND555 with 2x555ps
and its a pre-amp…
So you could have this with just a Klimax Twin or a pair of Solos…Nice.
Enjoy your demo :+1:
Are you going to use the “500 amp section”?
Does the synergy work?
( i presume it does :joy::sweat_smile::+1:)
Will you be using the preamp facility into your NAP500? Or maybe just the streamer into your NAC552? I’d be interested to read your thoughts if you were to compare both options.
Loving my new rack.
That’s very smart. The only thing I’d say is put the Napsc on the floor round the back, as it won’t be helping the Headline.
Currently set-up with WH Morgana RCA-Din into 552…will run it like this for a week, then ask dealer if he will set it up into the 500 directly…and compare…
Are you going to, or have you tried a pair of Solo’s instead of the NAP500? I’d be interested to hear your thoughts.
Oh really? Ok, thanks for that. I do like all the power supplies to be on show. How else would you have the layout?
Haven’t tried that partic option as yet…exploring several options…(also need to consider how the TT fits in..)
e.g. thinking about retaining Naim amp/s, going active ATC, replace 552/500 with a.n.o. power amp, replace 552/500 with a super-duper integrated (with phono stage)…
meanwhile sounding good this Bank Holiday Saturday am…enjoy
and the sun is shining ! (view from listening room).
Preamps do like to be kept away from power supplies as much as possible, which is why Naim separates always have their PSU in a separate box which should, ideally, be kept on a separate shelf on the rack. I would guess that your Headline would be the same in this respect, so HH has a point. Trouble is, you have run out of shelves. Probably the best solution would be to give the Headline a little stand of it’s own somewhere.
Obviously, if it sounds good to you as it is now and you don’t want to change your layout, you shouldn’t worry too much about it. Life’s too short.
I’d just hide the Napsc on the floor round the back. The performance of the Headline is compromised by placing it on the Napsc so it depends whether sound or show is most important to you.
