System Pics 2021
I have an Aria on my LP12. It replaced a Stageline powered by a 252/Supercap and is a substantial improvement so it should be superior to the built in phono stage in your amp. Are you tempted to lower the wall shelf a few inches now the hum has gone or would you rather avoid the resulting drilling and filling?
Keith
The main challenge is that the paint we used is discontinued, so any filling means a total redecoration of the room. The shelf does perhaps look a bit high but itā€™s ok and we can live with it.
Thank you. What are your experiences? I am currently looking for speakers for Nova/ NAP250DR.
What I read is that A4 and A7 are good, D7.2 Not easy with Nova. I heard the A4, but falls back against Linn Majik140. Unfortunately, I canā€™t hear other spendors at home.
Iā€™m guessing youā€™re using Farrow & Ball paint - as far as Iā€™m aware all of their discontinued colours are still available to order.
This should never be a problem for any paint colour as all thatā€™s needed is the correct code to put into the mixing machine and it will produce the colour you want.
It just looks ā€œindustrialā€ compared to the nice wooden rack. In my opinion, of courseā€¦
Lovely Titan 606s :+1:
Just as a point of interest, how are you finding the Kudos speaker cable? Iā€™m using Tellurium at the moment with my 606s.
Wonderful looking speakers and overall system - very cool. Do the speakers just sit in the floor?
Gary
I like the KS-1 but the only cable I can compare it against is its predecessor that I was running for 6 months with the system - WH Phantom. The Phantom was no slouch (it was an upgrade to the Chord Epic Twin I had before that) but the KS-1 improved the clarity of the treble for sure. I understand itā€™s the same cable thatā€™s used internally within the speakers too?
I know exactly what you mean, of course. In its favour itā€™s made by Rega as the ideal support for their low mass decks and itā€™s really easy to fit, unlike many wall shelves. Our speaker stands are hardly elegant, made purely for function. Iā€™d like to think of the speaker stands and Rega bracket as industrial chic, built for performance rather than to feature in Ideal Home.
Thanks Chris. I will check it out. The colour is ā€˜Fawnā€™, which works well and Iā€™m not keen to change.
Look for F&B ā€˜Archiveā€™ colours, they list all their discontinued colours there, still available, just not listed on the current colour chart.
Iā€™ve never been tempted to go back to vinyl. However, my biggest ever hifi ā€œwowā€ moment (even more than a ND555) was when I was in my late teens and I hooked up a Rega Planar 3 to my NAD amp and Monitor Audio speakers. Funny how you remember these special momentsā€¦
The problem with that is the the NAP300 head units would be one Fraim level up compared to the PSUs and Iā€™m not sure the Burndys would reach.
But then thatā€™s not an issue for the ND555 Burndys so might be worth a tryā€¦
MUSO Gen 2. A day for chilling in the ā€œreading chairā€. Trying to avoid having to put the Christmas decorations up!
Itā€™s COD not CDO!
Hi Graham, i am not entirely sure it made a big difference moving the amps up. Without the empty basement it sure looks tidier but then this huge trafo does radiate sideways directly towards the bottom amp.
You also may find it advantageous to stack the amps and respective pss in a crisscross manner.
Amps Top Bass. Pss top tweet
Middle mid. Middle mid
Bottom tweet bottom bass
This is a dream system for all of us
Welcome to the forum @davidking.
CDO is the alphabetic arrangement, and appeases mine. If COD works for you, thatā€™s fine too. :thinking:
Not quite the same with S-600s as they arenā€™t three way, so one amp is for BMR, the other two are for bass.
Curious as to what benefit arises from mixing in this way as the PSUs are still physically close to a head unit although not the one they are directly powering. Havenā€™t heard of someone doing this before, can you elaborate?
Nice set up BTW :slight_smile:
Many paint stores also have a digital tool that can be placed on a painted wall and analyzes the colour and determines the formulation needed to achieve the same result. In the USA Sherwin-Williams makes such a tool.
