Same here Stuart
As you say , before too late
Same here Stuart
Fantastic alternative place, @Mark84 ; if you, I would try separating those gorgeous DIY standmounters one more mere span from the back wall if possible.
You need to try harder!
Finally got round to putting my Hutter rack back in to action after a house move last year (took a while, forgot I had it) in my home office system.
Reterminated the speaker cables and sorted out the sockets and electrics as well.
May put one of my Rega decks in the mix at some point hence the empty shelf!
Lamp in the corner for anyone interested is a vintage Reggiani, late 60’s / early 70’s from memory.
Thankyou, I was not aware I had to do this, I plugged the nap200 and it worked… if I switch the nap off the sound stops and there was a very obvious lift in the sound when I plugged it in. I have gone through the settings menu and there is no mention of adding a power amp/switching the Superuniti2 power amp off, won’t it be ‘plug and play’ with the plugging in of the nap switching the internal power amp off?
wonderful room
It’s because my Hispanic sense of humor lacks English phlegm…
Section 4.4 of the manual, I think
Just got the new SCM40a installed. Very impressed so far.
Also moved the rack order to put the jewellery that is the nyquist on full display
Sorry I have not dusted… life is too short😉
At least it’s not a bird nest on a ground plane build arrangement.
You made an attempt it seems, still counts!
Wow, the DIY speakers look amazing! So is the room setup!
Mine is a Uniti 2 not a superuniti - my mistake, there was never a superuniti2… so it has 4 pin din pre amp socket - for those wondering about this the amp needs to be switched via the speaker menu in settings for the Uniti lite and superuniti, not so for the unitiqute 2 and NaimUniti2
My rig in Baden. The Dalis just arrived, they have zero hours.
Please have mercy, I am in a hotel room.
You’re joking right!? Top marks for carrying that lot to a hotel room!
