System Pics 2022
Oops, my mistake. That was a misleading way of stating the price. I meant to say that the K10s are $20k more than the K6 sig’s. Didn’t mean to imply that you can get the 10s for $20k. Very sorry!
Loads about 400 onto an external SSD plugged into the USB on the back
Ok; that’s clear.
Although nor in that case, cause once you already have the K6 in property and with more than 3 years, it is quite difficult to obtain more than half of their brand new price for them in the sh market, not even in a good offer by the dealer or distributor for the swap. Consequently, to have certain guarantees of being able to upgrade them, with their current rated price, you would need to have closer to about $40k than $20k burning a hole in your wallet. This is already beginning to be a significant amount of green, even more so as things are getting at full speed…
Thank you Chris. Unfortunatelly it is not possible to aquire here where I live, but will check with Cymbiosis.
I’m sure Peter could make a set up for you. He practically invented the Airplug.
I have just recieved my Urushi back from Ana Mighty Sound. Althogh I have not installed it yet, it looks just perfect. The work is done in Budapest, Francois handles things in Paris.
It’s well worth it. Even a 25 Ohm change in air plug resistance makes a noticeable difference with a Superline.
Enjoy, BF
Thank you Chris, I will ask him.
Pondering which tracks to put on this recently acquired tape ……
So will the “new classic” boxes (in the look of nova etc) be called “plastic bottoms?” :grinning::grinning::grinning::grinning::grinning:
Metal tape? Hmmm, maybe Rusty Nails by Moderat? :wink:
Wheels of Steel by Saxon?
Silver Machine by Hawkwind?
This one could run and run :stuck_out_tongue_winking_eye:
New rug, Kudos KS-1 and IsoAcoustics Gaia 3… all great upgrades and steals for the price.
Hi,
Which Naim amp and pre amp you had before?
As a sealed cassette it’s almost worth its weight in gold. Just a shame that the wrappers on these early ones tend to go brittle. Anyway, the early MA and MA-R (which, IIRC used selected MA tape) was a pretty good tape but hissy, so you may be best off recording it with Dolby.
A little radio, to anticipate any power cuts
Good choices! Much better than that lame female vocal rubbish that seems to be so popular.
I have owned Unitiqute 2,a Supernait 2, 272/Xpsdr/250 DR, an NDS and an ND5XS2.
Thats it I think.
A bit like “The New Originals” band.
A few items added since last posting an image, LP12 and Rega Fono then to finish of the black box count new HiCap DR.
Definitely need another shelf not ideal having the two power supplies on the floor, the wife isn’t impressed either " hope they’re not staying there!"
